HP LaserJet 1200 Printer Logo
Paul Midigo Posted on Apr 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer does not reset - HP LaserJet 1200 Printer
honey
Level 3:
Master:
  • HP Master 262 Answers
  • Posted on Jan 26, 2018
honey
HP Master
Level 3:
Master:
Answers
262
Questions
Helped
320357
Points
1535
HP tech support might help you in this matter you can reach them directly on this number (877-690-9305) or just follow the link Support For Hp Printer
Res Yarcia
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Apr 23, 2013
Res Yarcia
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
23677
Points
115
NVRAM initialization/cold reset
NVRAM initializer sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initializer resets the following:
! all menu settings to factory default values
! factory settings such as formatter number, page counts, factory
paper settings
To perform NVRAM initialization
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
4 Release the GO button.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Or download the service manual here ..
http://www.google.com.sa/search?site=webhp&source=hp&q=hp+laserjet+1200+printer+service+manual&oq=+HP+LaserJet+1200+Printer+service+&gs_l=hp.1.0.0j0i22i30l6.200423.206442.0.207913.10.10.0.0.0.0.763.3187.0j3j2j3j1j0j1.10.0...0.0...1c.1j2.9.hp.QNDAx6nGCA0
14helpful
6answers
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
1helpful
2answers
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Reset canon ipf750 to factory default
How to Reset Canon Printer A Complete Guide To Reset The Canon Printer In Different Ways
Canon printers are quite known for their top-notch print services and exceptional features across the world. However, there are times when Canon users face issues with their printing devices, and this sometimes leads to resetting their devices. In addition, due to daily developments in the device's technical systems and user interfaces, users also face confusion with the printer reset process.
Now, if you are also a Canon printer user and have been looking for info on the device reset process, then you can refer to this guide here. Here, you'll be guided with all kinds of ways on how to reset a Canon printer.
What happens if I reset my Canon printer?
When troubleshooting your Canon printer, You may need to reset or restore the device completely. Factory reset will return the printer to its out-of-the-box settings.
Quick Methods To Reset The Canon Wired Printers
Resetting the Canon printer lets you bring it back to its normal functionality. Plus, this also resolves any major or minor technical issues in your device such as slow printing issues, the printer being unresponsive or getting online, etc. In this guide on how to reset Canon printer, you will get to know about the following ways to reset your device.
  • Power reset of Canon printer
  • Ink reset of Canon printer
  • Hard reset of Canon printer
  • Resetting Pixma Printer
  • Factory reset of Canon Printer
Therefore, read further to know about each Canon printer reset process in brief.
Power Resetting of Canon Printer:
Although a power reset is a type of soft reset type, it can still bring your Canon device back to its normal functioning. Here's how.
  • At first, turn off your Canon Printer, then remove the power cable from the direct power source, and then ensure that your device is completely disconnected.
  • Now, plug back the power cable in the power socket, then turn on the device, and then connect it to the Ethernet cable.
  • Finally, try a test print to see if the issue has been resolved on your Canon device.
Ink Resetting The Canon Printer:
Inkjet printers such as Canon printers have an inbuilt special chip that notifies users about the need to refill ink cartridges when the old ones are low or out of ink. Now, replacing the ink cartridges may hamper the normal printing operations, but resetting them through other ways can help you better. Here's how to reset Canon printer ink and bring your printing device back to its normal functioning state.
  • At first, remove the ink cartridge of your Canon printing device, then insert it into the main channel of the ink resetting mechanism.
  • Next, you'll need to ensure that the chip on the ink cartridge is working fine and in good contact with the plate on the resetter.
  • Now, hold the ink cartridge softly for a while until you see the LED light on the chip resetter flashing. Now, hold the ink cartridge softly until the light becomes steady.
  • Next, you'll need to remove the cartridge from the chip resetter again and repeat the process on any ink cartridge that requires a reset.
  • Finally, install the cartridges in your Canon printer and see if the issue is resolved.
How Do I Reset My Canon Printer To Factory Settings: Hard Reset
The hard reset can help you to bring your canon printer back to its default factory settings. Here's how.
  • Initially, hit the "Stop" button until you hear the alarm ringing on your Canon printer, then release the "Start" button only after the alarm flashes or rings at least 19 times.
  • Now, that your device is restored to its factory settings, you'll need to uninstall your device's drives from your computer network and reinstall them with the latest drivers available.
Resetting Canon Pixma Printer Via Default Factory Settings:
If you have a Pixma device and you wish to reset it, then follow the steps mentioned below on how to reset Canon Printer Pixma.
  • Turn on the Pixma printing device, then locate the Device Settings from the menu using the arrow.
  • Press Ok, then select the "Resetting" option, and then again press "Ok" to begin with the device resetting process.
  • Now, turn off the Pixma device, then hold the "Stop" button along with the power button of the device.
  • Hereafter, release the "Stop" button, then again press the "Stop" button two more times while you hold the "Power" button.
  • Wait 30 seconds until you see the "O" on the printer's screen, and then press the "Stop" button 4 times.
  • Next, press the "Power" button two more times, and then press it again for once to turn off the device & complete the reset process.
Via Resetting Pixma Ink Cartridge:
The following steps will help you on how to reset Canon Printer Pixma via resetting its ink cartridges.
  • At first, unplug the power cables and other USB cables from your Pixma device as it'll help you to reset Canon printer or the ink cartridges.
  • Now, press the "Power" button to open the ink cartridge door, then reconnect the power cables along with the power button still functional.
  • Finally, close the cartridge door, then release the power button, and the ink cartridge reset process is now finished.
How to Factory Reset a Canon Printer: Instructions +1-820-333-4168
They can be times when you may need to troubleshoot your Canon printer while working with it, hence, resetting it completely can be a major part of it. In this way, your device will return to its out-of-the-box settings or default factory settings. Here's how to factory reset Canon printer.
  • Press Setup on your Canon device, then navigate to Device settings through arrow keys and press OK.
  • Now, navigate to Reset setting, then press OK, and then navigate to Reset all option.
  • Press OK, then select Yes, and therefore, your device is now reset.
For more assistance on how to hard reset Canon printer, contact the technician expert at Canon printers.
Reset Your Canon Printer Without Software:
  • Make sure the Canon printer is turned on and connected to your computer.
  • Now press the power button to turn off your printer.
  • Once your printer is turned off then you press the stop button for 2 seconds.
  • While holding down the Stop button, press the Power button at the same time for 2 seconds and then release the Stop button.
  • While you are holding down the Power button, at the same time press the Stop button 5 times.
  • Now after pressing the Stop button 5 times, immediately release the Power button.
  • Your printer is now completely reset.
1helpful
An error appear in lcd screen of canon Mp550 is 5b00 please send to me an urgent soluation
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
2helpful
En la pantalla de mi impresora aparece error 5B00 digame q puedo hacer?
9helpful
I have an error code 5B00 on my Canon MP830 printer. Can you help?
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink wastepad replacement, if you want your printer to work again. There are two ways to reset the Canon MP830 printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using Mptool Software to reset Canon MP830 Printer
4helpful
ERREUR 5B00
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
3helpful
4answers
Reset C48 printer
i need to reset my c48 anybody help?
k24674
Grand Canyon Tech
Grand Canyon Tech
