Justin Posted on Apr 14, 2013
Foggy projector lens - Office Equipment & Supplies
jvsvisual
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Apr 19, 2013
jvsvisual
Contributor
Level 1:
New Friend:
Answers
29
Questions
Helped
17979
Points
40
Possibly panels not len assembly is picture colours ok but foggy if so remove lens assembly and view it itself if foggy could be faulty lens or a lens sometimes plastic lens's did this
john www.jvsvisual.com
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
  1. Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
  2. If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
  3. If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
6helpful
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 • Cameras
It's not clear. Like it's kinda foggy, Kathy
Is the eyepiece lens clear or dirty? Are any of the other lens dirty?
If not practice focusing on a distant object during the day time. Clean the lens and eyepiece with regular eyeglass cleaning solution and a clean soft towel or pure white kleenex.
May 13, 2010 • Optics
My sony cybershot DSC-H10 camera has a foggy screen
is screen is foggy/image formation is foggy,chaque the lens unit
2helpful
3answers
1999 taurus has foggy headlights.
Most Auto Stores sell a headlight solution that cleans the fogginess of your headlight. Assuming your headlight looks dirty and cloudy as would a pool, a simple solution is to pick up the cleaner at any auto place. That is a lot cheaper than buying a new headlight.
My quick cam pics are not clear also vedeo seems foggy why is tha
rotate the lens in order to focus objects in front of it
(lens is the purple part looking like a ring on the front of the cam)
Kodak c340..water in lens...
i kept the camera on, that means the lens was open too..........after a good 4-5hours later when i checked it was back to ''foggy'', and another few hours later it was back to normal.........hurrah!!
Fogging problem (i.e.) screen is foggy at start up but clears 20 to 30 mins use.
what is model number of your Sony tv to provide you info about foggy picture problem.
k24674
ADMIN Andrew
ADMIN Andrew
