Health & Beauty Logo
Posted on Mar 07, 2009
Jazzy 1200 power wheelchair is electrically inoperable after owner fell on back of chair at night. Battery was charging at time of accident. Believe problem may be in multi-pin connector betweenjoystick and control unit in chair base. Need electrical diagram for system
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2470
Points
9
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
What does it mean on 1122 jazzy when the two red lights blink
JAZZY 1122 - Pride Mobility Products
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1...
Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Power light is on the charger but no movement from the jazzy select chair
You have to disconnect the charger in order for the chair to move. It automatically removes power from the controller while the batteries charge.
1helpful
2answers
How do i know if my jazzy power charger is working
Without the charger the batteries would go dead. You could put a voltmeter across the batteries and you should read more than 28 VDC while charging.
7helpful
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
1helpful
I think my charger isn't charging the batterys
Have someone check if the on board charger light is green after you have charged it all night. Most probably you have a charger problem and this will also create a battery problem since you haven't been charging them with a bad chargger. If medicare purchased your chair then you can find a repair service to repair your chair and Medicare will pay for most of the repair
Power chair worked when we bought it from previous owner but has set for awhile, we pluged it in to charge the chair as it would not work, charged for lenght of time book said but still will not run
If the chair sets for several weeks the batteries will wear down to the point that they cannot be recharged. Have the batteries load tested and I bet that this will fix the problem.
1helpful
I have a Jazzy power chair on loan and there is no instructiion book. How do I recharge the chair? I know I plug it in but do nmot know if it is actually recharging, Thanks
Be sure to charge the chair at least 8 hours each time. If you use it charge it. If you charge it less than 8 hours than it starts taking away from the life of the battery.
1helpful
Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Battery won't charge
First make sure that all the connections are tight. Then have the batteries load tested.
1helpful
We have a Jazzy 1113 Power Chair. The chair is fully charged, but does not move. What might be the problem?
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
