I have a toshiba satellite c655d s5518 with backlight issues. I have replaced both the lcd and lcd power cable and hooked it to an external monitor to check the gpu. Gpu is working. I am stuck. Please help before I have to go buy an brand new laptop.
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
SOURCE: Toshiba Satellite P105-S9722. monitor will not
The problem is the inverter cable or the inverter itself.
If you have any warranty left on the laptop then i recommend you take advantage of that and send it in for repair, or you can deal with this 2 ways.
Fix the problem yourself.
Remove the screen bezel (plastic screen surround), this will
reveal the whole screen. At the bottom of the screen you will see an
elongated piece of circuit board with wires coming from either end
covered by frosted plastic.
That is the inverter, check the connections on the inverter and power the laptop up to check the display, to remove it
gently pull the plugs from each end and remove the screw from the
middle and pull the board away.
Look at the inverter for a copper coil, if you
re-solder the solder points around the coil you may find it works again
as components that suffer from extreme heat the solder joints dry
causing bad connections, re-floating the solder solves the problem in
90% of cases.
Take the laptop for repair.
In
this case all you have to do is source a reputable PC repair store and
take it in for them to fix. (it should be fairly inexpensive).
Good luck.
SOURCE: No Display/Beeps - TOSHIBA Satellite M115-S1061
There's nothing much you can do at this stage apart from get another keyboard with a function key and try to switch screens, other than that you could check the inverter board & connections there.
Remove the screen bezel, At the bottom of the screen you will see an
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it
Look on the back of the inverter itself for a copper coil, if you
90% of cases.
Good luck.
SOURCE: DIM BACKLIGHT TOSHIBA L305D-S5924 LAPTOP
There are also another reason , the Back light lamp might be damaged also!
SOURCE: New laptop lcd display not working
check all usb connections i just fixed a emachine that seemed to boot up but no display would show lcd or ext. so i got to looking and one off the usb ports was broke and bent downt into the opening and shorting out when i removed it and turned back on it started booting up as normal
I am sorry I should have been clearer about the type of screen I have. The screen is an led type with no inverter. If it was the inverter the problem would have been fixed when I replaced the screen. I have already bought a new laptop but I would still like to find a solution to this problem just in case someone else has it.
Well that eliminates the inverter. Do you get a "ghost image" on the screen? If you boot to safe mode does it work? I don't know how your Laptop controls the on/off of the monitor when the lid is opened or closed, mine has a tiny switch, that when operated by closing the lid it turns off the monitor, and when opened turns it on.I have repaired laptops with bad ribbon cable connections in the rear of the monitor. I have found if there isn't adequate slack will pull out a bit losing a connection. I use Electronic Contact Spray to clean all connections when i reassemble a computer. If the parts are the correct replecement parts, then I would suspect a loose connection. Just a thought.
Yes I do get a ghost image if I shine a light at the panel and also I have hooked it up to an external monitor to check the gpu. I have no problem seeing the image on the external monitor.
I have also replace the cable that goes to the panel.
Taht sound like a backlighting switch issue. Again, I don't know how your Laptop controls the on/off of the backlighting when the lid is opened or closed?
