I have located the set screw. When loosening the screw will not backout from the cartridge in order to remove handle and change the cartridge.
Do you have a picture?
Unfortunately no. I have removed the handle cover and when unscrewing it just spins without backing out.
On the set srew is a locking nut, first loose the nut, and after you can adjust it
Clarify. I have removed only yhe cover that exposes the screw. The handle itself cannot be removed due to the screw not backing oit
So, you are not far yet, I have no better idea, drill out the screw , Good Luck
