Dishwashers Logo
Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control panel on my whirlpool dishwaher not functioning properly
I have a whirlpool dishwasher, model # GU980SCGB3. The electronic control panel is not working properly. The only setting I can use is for China. Sometimes the normal cycle will work, but that is becoming less frequent. The other problems I am having are:
-Sometimes the washing cycle is over and out of the blue the cycle restarts.
-Doesn't always drain
-The delay option comes on when you press the cancel/drain button
Anonymous
Level 2:
  • Expert 188 Answers
  • Posted on Feb 20, 2009
Anonymous
Expert
Level 2:
Answers
188
Questions
0
Helped
97538
Points
916
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
2answers
Clean light blinks on whirlpool dishwasher won't run
If you aren't sure whether Control Lock is on, press a cycle button on the keypad. If Control Lock is on, the light will blink three times.
Turning off Control Lock:
  1. Press and hold the Lock Button for four seconds. The lock light will disappear.
  2. Once off, you should be able to start your wash cycle.
Note: If Sleep Mode is on, turn that off first, then turn off Control Lock.
Like many other electronics, you may need to reset the dishwasher control panel by turning it off, waiting, then turning it back on.
  1. Press the OFF button.
  2. Disconnect the dishwasher from its power source by unplugging it or by turning the circuit breaker off at the electric panel.
  3. Once disconnected, wait one minute, and turn the power back on.
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Dishwaher does not drain cmpletely ?
Hello friend, thanks for your post!
I see you are having difficulty with your Frigidaire dishwasher not draining. Check the filter at the bottom of the dishwasher because if that gets clogged then it will not allow your dishwasher to drain properly. Additionally, check to assure that the sump pump is hooked up correctly to allow proper siphoning of your dishwasher. If that is correct it could be a potential problem with your control panel or drain pump and I would recommend consulting with a professional technician for proper diagnosis and repair. I hope this helps to some degree. -Matt
GU980SCGB3
Check the thermal fuse on the control you have to remove the outer door skin to get at it
Feb 10, 2014 • Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 • Dishwashers
Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Mar 12, 2009 • Dishwashers
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 • Dishwashers
Dishwaher
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more).
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
