Have you been to the Compaq/HP website to check your specific model for updated Windows 8 drivers? It's tough to know for sure...but "Base System Device" and "Coprocessor" are possibly parts of the motherboard chipset..and the SmartAudio 221 component is also likely built in to the motherboard. I would do a search on the HP/Compaq website, and possibly find the right drivers using their support tool...it may identify them based on your serial number. Make sure they have Windows 8 compatibility. If not, you may want to go back to 7 for a while until all the drivers can be updated for 8.
SOURCE: conexant hd smart audio 221 driver for win xp
i have a hp pivilion dv2701tu, recently downgraded to win xp, problem is i didn't get the sound driver conexant hd smart audio 221 for win xp all over
SOURCE: i have the compaq f700 i have found all the drivers but 2 for xp
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click
Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp36090 folder and select the .inf (wis30b2a)
file and click open and Continue with the onscreen instructions
SOURCE: Conexant HD-Audio smart audio 221 Drivers for XP
have you tried going to the control panel and under sounds and audio devices and under the voice tab make sure nothing is muted or something like that? does it only not work on the yahoo program? you can see if it is working in other stuff by going to the sound recorder in start menu - all programs - accessories - entertainment - sound recorder
SOURCE: installed windows 7 and need sound driver
First go here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-51288-1 and download and save to your computer. Then go here http://www.sevenforums.com/drivers/7855-so-close-conexant-ac-link-audio-driver-11.html for help on installing the drivers
SOURCE: Conexant High Definition Smartaudio 221 driver is not detected.
Please get the driver here :
www.hp.com
www.techno-files.com/categories/laptop/531.html
www.opendrivers.com/.../hp-free-driver-download.html
Regards, Jay__ncbgd
I just recently upgraded my laptop to a Windows 8 Pro 32 bit system and I am finding that there are a few drivers that are compatible with Windows 8. One of them was the nVidia GeForce 7000 series. I solved that problem and now I am trying to figure out how to solve the problem in Device Manager under 'Other Devices'. I believe that it is because I need an updated Conexant Smartaudio 221 driver. Under other devices, I see that there is an exclamation point next to two labels of 'Base System Device' and 'Coprocessor'. Any clues where to start with this mess?
