20 Most Recent HP Compaq Presario F750US Questions & Answers
if you are looking for purchasing a new battery, contact any authorised computer hardware deale. they will provide you with one.
if you intend to repair it, you should loook for authorised notebook service centres present there. the nearest service proffesional coulde be located from the company website.
repairing a battery pack seems impossible.so i would suggest buying a new one
HP Compaq... | Answered on Mar 05, 2018
hello...G7 systems company has release very high quality configurised laptops at very less price compared to other company laptops...customer service and warranty period also good.for more details call me at :09480129287....i m from bangalore
for system configuration and thr price plase visit: http://218.248.40.19/laptopcompare.html
HP Compaq... | Answered on Jul 10, 2015
try eBay or amazon, they offers resonable rates.
HP Compaq... | Answered on Mar 23, 2015
he HP Compaq 6530 laptop series is the latest from HP Compaq.There are four new laptops in the HP Compaq 6530 series.Each of these have 14.1-inch WXGA display (1280×800).They are namely HP Compaq 6530b, HP Compaq 6535b, HP Compaq 6530s, and HP Compaq 6535s.
The b series are business series laptop which focus on mibility and the s series laptops are the enhanced security series which have added security features.
The b series laptops (HP Compaq 6530b and HP Compaq 6535b) has the intel mobile processors with Intel Mobile chipset whereas the s series laptops (HP Compaq 6530s and HP Compaq 6535s) has the AMD mobile processor with AMD M780G chipset.
HP Compaq... | Answered on Mar 07, 2015
Hmm give this method a try. Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases. Good Luck !!!
HP Compaq... | Answered on Feb 21, 2014
Have you been to the Compaq/HP website to check your specific model for updated Windows 8 drivers? It's tough to know for sure...but "Base System Device" and "Coprocessor" are possibly parts of the motherboard chipset..and the SmartAudio 221 component is also likely built in to the motherboard. I would do a search on the HP/Compaq website, and possibly find the right drivers using their support tool...it may identify them based on your serial number. Make sure they have Windows 8 compatibility. If not, you may want to go back to 7 for a while until all the drivers can be updated for 8.
HP Compaq... | Answered on Feb 28, 2013
Reboot , without battery installed, at start taping F-11 to enter restore/recovery , Advanced Options. Follow instructions. Take a look at this procedure: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673043&cc=us&dlc=en&lc=en&product=3646603&tmp_track_link=ot_search
HP Compaq... | Answered on Nov 25, 2012
contact microsoft tech support in your area, they'll give you whats called a hotfix
HP Compaq... | Answered on Sep 23, 2012
It's usually F11 or Fn+F11 at the bios startup screen to enter recovery mode.
If that doesn't work, let me know.
HP Compaq... | Answered on Sep 22, 2012
You'll spend more money trying to upgrade this laptop then it would cost to just buy a better used one on eBay. Probably even spend more that it would cost to buy a new low end computer. Save yourself the headaches and time and buy a NEW laptop.
HP Compaq... | Answered on Jun 14, 2012
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
HP Compaq... | Answered on Oct 20, 2011
1.Clean your RAM
2.Replace RAM
3.Change your LCD
HP Compaq... | Answered on Sep 29, 2011
Hi!!
Here are some links where you can get drivers for your HP Compaq Presario F750US. Please click the appropriate OS for your computer.
HP Compaq Presario F750US drivers:
Windows XP
Windows Vista
Windows Vista 64bit
Hope this can help. Take care.
HP Compaq... | Answered on Jul 21, 2011
You can do these procedure to correct the problem , Start in safe mode press F8 during boot up of your computer and select the C> prompt. Use the following commands: bootrec.exe /fixmbr and then bootrec.exe /fixbootand hit enter.
But after doing that procedure and problem is still there you really need here a operating system dis to correct the problem or a recovery disc for your computer that you can request from the manufacturer.
HP Compaq... | Answered on Jul 03, 2011
The motherboard of your laptop might have encountered a short circuit. If you've already removed and reseated all possible removable parts and still get the same result, purchase a replacement motherboard or check if it is still under warranty.
Good luck.
HP Compaq... | Answered on May 17, 2011
you only reasonable option is to find a disc that (should have ) came with it.. you should be able to reinstall/upgrade vista with that disc (if you bought the laptop as a vista computer)
HP Compaq... | Answered on Mar 01, 2011
If your laptop is on and shutting down because it is over heating then you dont have much choice but to replace the fan. Which you can check this manual. Starting at page 71.
http://h10032.www1.hp.com/ctg/Manual/c01295900.pdf
Or.........
You could try something like this. An external cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16834997396
HP Compaq... | Answered on Feb 02, 2011
HP Compaq Presario F750US Logo
Popular Tags
184 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
upgrade hp compaq presario f750us cpu
  • Computers & Internet
