Fresca uses a silicone material on their flapper that will distort after a while. There are also ridges on the underside of the plastic surface of the flapper that seals the tank which allows water to seep past. To this point, I have not been able to find any material that would work as a replacement. To add to that, Fresca does not sell the flapper individually, leaving you to buy the entire flush assembly as a 'purchased' fix. Not a good solution, since it will only start to leak again.
I am still searching for a solution to cure the problem once and for all. It's a great looking toilet but I prefer not to waste innumerable gallons because of poor design / materials.
I PURCHASED A FRESCA TOILET APUS DOES NOT FLUSH STRONG
