20 Most Recent
Toto Aquia II Dual Flush Toilet Questions & Answers
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Toilet buttons will not come back up, hence water keeps running
Could be a few reasons, an ill fitting or cracked dress cover can sit to low, or abrasive wear and tear can grip the button restricting it from free movement. I fixed mine by placing a couple of small fishing sinkers in the bottom of the plunger giving it a little more weight.
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
