20 Most Recent
Toto Toilet Onepiece Ultramax MS854114SL.12 Questions & Answers
My ultramax won't empty the
The wax seal may be restrickting the flow of the water so it cant excape fast enough so the waist still wants to float instead of going with the sintrivical fource.Hope this fixes the problem.
Hi,I've just had a new wc fitted and the waste
What you describe seems to be very poor workmanship and is, in most areas of the U.S. illegal. Have it fixed properly by the plumber who did the work or report them to your local building authority.
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
The chain keeps getting tangled and the toilet
there is too much slack in the chain. when the handle is at rest, there should be very little slack in the chain. and when you flush, don't slam the handle. also, if the handle is all the way down when you flush and the flapper is being pulled too high, leave a one link slack. and the hook that holds the chain, clamp it closed to avoid the chain getting rehooked on it.
How do I get the old toilet seat fastener bolts
On top if you look closely you will se that where the hinge is you can lift up a plastic cap and see the top of the screw. From there you can remove screw. It should be a flat head screw.
Good Luck
Water want stop pouring
remove lid from tank.see that 'flapper valve' in bottom of tank is seating to stop flow into bowl.adjust chain linking flapper to flush handle. replace worn or broken parts
Toto toilet - inadequate flushing
if this has been the case since the toilet was in stalled the problem is probably with the venting of the plumbing lines. try switching the toilets and seeing if it still happens with the "good" toilet.
