Xerox WorkCentre M-24 Color Copier Logo
Posted on Feb 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System not initializing
Our system is model WC 255. Our problem is this, when switch on the following messages are coming.
System unavailable. Do not power down until the power down message appears.
After some time following message is coming.
Communication error
Try powering down then on again
Please call for assistance if problem persists
Can u help us?
  • Anonymous May 13, 2009
    I have the same problem, on the first I thought that is Firware cuase a problem, I change the firmware same problem...
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Feb 11, 2009
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1110283
Points
5835
Does the machine have a network box on back? Frequently on that product the boards in the network controller come lose, and simply need reset.
You can unplug all accessories and see if it powers up then, then connect them back one by one and see which one causes the failure.
  • ZuZu FreeMan
    ZuZu FreeMan Jan 07, 2016
    hi, i got the same problem with a xerox 238, but it doesn't have any network box ( is used just for coping) i changed main bord, and i got same error! HELP!
Hp psc 2410 starts ,display screen comes,scanner light moves on reverse it gives creaking sound and display does not initialise .this problem sometimes is resolved but when system switch on again creaking...
Are you getting error messages? This sounds like it could be a mechanial issue that may require service; however you might give this a try.
Scanning Stops at the Preview Screen When the Device is Connected to the Computer with a USB Cable
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00803473&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=303753
Follow the instructions at the link above.
If that does not help I would check to make sure my driver is up to date for my operating system. See:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=303753&
Trust this is helpful. :)
tip
Film on dishes; dishes not coming clean
A lot of dishwasher problems either stem from build up, hard water or the non phosphate soaps. To eliminate this as your problem take a bowl and fill it with apple cider vinegar (you want cider vinegar because of the citric acid, you can also use tang or frozen o.j) then put the bowl full of vinegar on the lower rack in the dishwasher, do not just pour the vinegar into the bottom of dishwasher because the dishwashers 1st cycle is drain so it will all just drain out. Run the dishwashers heaviest cycle with nothing in the dishwasher but the bowl of vinegar. This will clear out all the debris and hard water deposits throughout the dishwasher. If it seems to clear up your problem try changing your dishwasher soap to Finish I work at a service company and have found this to be the best dishwasher soap on the market. Hope this helps.
on Apr 21, 2012 • Dishwashers
tip
How To Reset Your Mobile Phone
You can return your phone to its original state, as it was when it left the factory. This is also called a hard reset. You might want to do this if you are giving your phone to a friend or relative and you want to remove all your data first, or if your phone has a persistent problem that is not solved by powering off the phone and then powering it on again.
A factory reset is a drastic measure. It permanently erases all your personal data and customized settings, and also removes any programs you have installed. Make sure that you have backed up the information and files you want to keep.
As different phone models have its own reset procedure, view complete list here.
on Jul 09, 2011 • Cell Phones
2helpful
3answers
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 • Cell Phones
tip
Unlock Your Nokia mobile phone with Code Calculator
What is Unlocking?
Unlocking a mobile phone is the procss of removing any SIM Card or Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider. After unlocking a mobile phone, you can still use it with it's existing network or switch over to any other supported network.
Get free unlocking codes here
Windows 98 will not load.
There is a Microsoft article that gives a number of steps to follow to try and rectify this problem. You can view it here and come back to us if you still have problems.
tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
