20 Most Recent Microsoft Windows 98 for PC Questions & Answers
tru following steps
1) plug in usb device
2) change your boot option to cd from hard disk
3) insert installation disk in cd drive.
4) follow the steps.
5)finalize instalation.
Enjoy !!!
Microsoft... | Answered on Feb 23, 2018
This happened with MS Windows some times if you don't want to say..it's often :)
Okay, this what you should do:
Download the missing file from here: http://www.dlldump.com/cgi-bin/testwrap/downloadcounts.cgi?rt=count&path=dllfiles/M/MLANG.DLL
Then, follow the instruction below:
How to install/uninstall MLANG.DLL? 1. Unarchive the package and use the files from Release folder if you're running windows 9x/Me or Release Unicode if you are running windows 2000/XP
2. Copy DLL files in system32 folder [C:\WINDOWS\system32]
3. Click on Start > Run
  • To install the dll files, type: regsvr32 MLANG.DLL
  • To uninstall the dll files, type: regsvr32 -u MLANG.DLL
  • run.gif 4. In the end, you should receive a message saying that your file was successfully installed/uninstalled
    P.S.: If this information was helpful, please rate this solution.
    Microsoft... | Answered on Sep 12, 2017
    Try transcend D33193 another port back side on cup or front side on cup
    Microsoft... | Answered on Nov 25, 2016
    What OS is the phone. Windows,Android or iOS. Depending on which one there are a number of downloadable programs that will track your phones location. You install the app on the phone. Register it and then go to you computer and to the apps web site and complete the registration process. if you lose the phone you go on your computer and activate the tracking feature. Some will even allow you to disable the phone.
    Microsoft... | Answered on Nov 23, 2016
    HQ6K2-QPC42-3HWDM-BF4KJ-W4XWJ
    Microsoft... | Answered on Nov 07, 2016
    hey there i myself experiance the same problem just win+R then type msconfig
    startup
    disable all except the anti virus
    then restart and check it
    Microsoft... | Answered on Jul 21, 2016
    i dont have key for windows 98 help me out
    Microsoft... | Answered on May 19, 2016
    ya its asking the windows 98 cd key
    try this
    Follow the steps below to locate your Windows 98 product key code from the Windows 98 registry.
    Difficulty: Easy Time Required: Less than 10 minutes Here's How:
    1. Click on Start and then Run.
    2. In the text box in the Run window, type regedit and click OK. This will open the Registry Editor program.
      Note: Do not make any changes to any entry anywhere in Registry Editor to avoid causing serious system issues. These steps only direct you to view entries, not to make changes.
    3. Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+) sign next the folder name to expand the folder.
    4. In the resulting folders, locate and click on the (+) sign next to Software to expand this folder.
    5. In the resulting folders, locate and click on the (+) sign next to Microsoft to expand this folder.
    6. In the resulting folders, locate and click on the (+) sign next to Windows to expand this folder.
    7. In the resulting folders, locate and click on the Current Version folder.
    8. In the results that appear in the window on the right, locate the ProductID.
    9. The numbers and letters on this line represent the Windows 98 product key. The product key should be formatted like xxxxx-xxxxx-xxxxx-xxxxx-xxxxx - five sets of five letters and numbers.
    10. Write this product key down exactly as it is found here for use when reinstalling Windows 98.
      Note: If even one character is written down incorrectly, the installation of Windows 98 that you attempt with this product key will fail. Be sure to transcribe the key exactly.
    11. Close Registry Editor without making any changes.
    Tips:
    1. If your system was purchased with Microsoft Windows pre-installed, and you have not reinstalled it or upgraded it yourself, the product key found by the steps on this page will only find the generic product key that your computer manufacturer used to install the operating system. This product key will not work when attempting to reinstall Windows. In this case, you must use the unique product key that is on the sticker attached to your computer case.
    2. rate me solved if its helps thx
    Microsoft... | Answered on May 05, 2016
    Is this occuring during the install?
    If this is the case, try this (it will be useful to know when the problem occurs):
    Go to the VM Settings
    Go to System
    Go to Acceleration Tab
    Uncheck Enable VT x AMD V
    I hope that helps.
    If not, there is a guide on the virtualbox forums here
    Which I would suggest trying to run through instead.
    Microsoft... | Answered on Apr 27, 2016
    Mary can you confirm what your operating system currently is.because the category doesn't match Windows 7. Also if Windows 7 download centre only has service pack 1 it probably does not have service pack 3
    http://www.microsoft.com/en-us/download/windows.aspx
    http://windows.microsoft.com/en-gb/windows/service-packs-download#sptabs=win81
    Microsoft... | Answered on Apr 25, 2016
    :L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
    Microsoft... | Answered on Jan 26, 2016
    not for 98SE i believe. a great OS but MS most likey deleted those from their servers long ago. if you can find someone else who has a system with 98SE you may be able to copy and install them from them. someone who is really old and smart "CE" maybe could program them:) for you but, you should have backed up your system and drivers before this repair was needed
    Microsoft... | Answered on Dec 27, 2015
    which toolbar are you talking about
    Microsoft... | Answered on Nov 13, 2015
    I don't think this will work, there are no drivers available for XP on that Notebook. Experience tells me also, that HP is very restricted in delivering drivers for not supported OS. Remember XP is out of Support, so a vendor needs no more support for such OS.
    Microsoft... | Answered on Mar 04, 2015
    A backdoor trojan is a bad. They are a sort of virus with the capability of sending information back to the controller of it. It can be downloaded and can turn on without you knowing it and then it will follow whatever instructions it is given. The information it can send out is worse than any damage it does to your system. Passwords, bank info, credit card numbers. It can even email your contacts using your account.
    System restore does record and copy these, and you need to turn system restore off during your scan and removal process. System restore does not allow virus software to remove these files.
    First, update your virus program and then turn off your internet connection. Then turn off system restore by going to your control panel>System>and then click on the System restore tab, usually in the back. Close those windows and and start your virus scans. Follow the instructions after it locates the virus. If you have the option of deleting the virus, do that rather than put it in quarantine.
    Since you have a program running that you don't even know about, it can certainly put a drag on your system and slow things down. Your Windows OS is so old, I can't believe it is still running. Congrats, everyone I know had a fatal crash by this time. If you need further help, please leave a comment. Thanks for your question.
    Microsoft... | Answered on Jan 04, 2015
    Found this which may help:
    Here is what you need to do.
    1. Press the WINKEY+R to bring up the Run dialog box.
    2. Type SLUI 4 in the box and press OK. This will start the Telephone Activation Wizard.
    3. Select your country in the drop down menu and click the Next Button. Follow the instructions on the screen and call the number that is shown there.
    Follow the recorded instructions and when the telephone activation fails, stay on the line and an Activation Representative will answer. Just describe the problem you are experiencing and they will manually activate the system for you.
    Microsoft... | Answered on Dec 18, 2014
    I THINK IT IS FUNNY HOW PEOPLE MUST BE PUSHED TO BUY A NEW WINDOWS. THE SIMPLE ANSWER IS PORTABLE BROWERS. USE THE LATEST HBCD 15.1 DISK. IT IS FREE AND HAS A PORTABLE BROWSER THAT YOU CAN US OR GO TO WWW.NINITE.COM AND DOWNLOAD FIREFOX OR GOOGLE CHROME AND TRY THEM. I STILL HAVE A CUSTOMER WHO STILL USES WINDOWS 3.1 ON A NEW COMPUTER. NOTHING IS IMPOSSIBLE. IT IS NOT EASY BECAUSE THE KNOWLEDGE OF THIS IS UNCOMMON. IF YOU NEED HELP LET ME KNOW. Jerardi@gmail.com. JUST LIVE BOOT CD TO BE EDUCATED ON THS AND SIMULAR OS'S.
    Microsoft... | Answered on Nov 09, 2014
    Microsoft Windows 98 for PC Logo
    834 questions posted
    Top Microsoft Computers & Internet Experts
    Alun Cox
    Peter Dragonetti
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Microsoft Computers & Internet
    Most Popular Question
    dell inspiron 1525 c2d 250gb hard disk
    • Computers & Internet
