ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
Some consoles require batteries. Check to see if this is the problem. If the console does not use batteries, move on to Step 2.
Remove the key from the console.
Unplug the power cord.
Remove the screws from the console hood and remove the hood.
Turn the pulley until the reed switch and magnet are aligned with a 1/8-inch gap between reed switch and pulley.
Replace the hood.
Plug in the power cord.
Reinsert the key into the console.
Run the treadmill to check for a correct speed reading. This may take a few minutes.
HI , Check this link for more details about PRECORE error codes http://electro-medical.blogspot.in/2013/...
