20 Most Recent Proform XP Weight Loss 620 Treadmill Questions & Answers
ProForm XP Weight Loss 620 Treadmill: i have lost the kye can it start running without i...
Generally NO, but try something like a fridge magnet, it worked for me on my HyperExtension treadmill
1/18/2023 2:11:20 PM • Proform XP... • Answered on Jan 18, 2023
I am assembling the ProForm 705 Trainer Model
You probably have a nswer by now (or have given up and bought other screws, but I have to tell you we just had this exact problem! We rubbed the screws on a bar of soap. then they screwed in just fine. Its still very tight, but they go in all the way.
We also first screwed them directly into the handrails without the crossbar on to make to make sure we could get the screws all the way in (as the drilled holes were not perfect). But I think the main trick is really the soap.
3/6/2022 6:29:53 PM • Proform XP... • Answered on Mar 06, 2022
4answers
Proform 860QT treadmill give jerks while running
dear at first you must do a little relax your belt and reduce force on motor and check is it good or not . you can countiue contact us with smart phone on wattsapp or telegram by : +989195116738
8/21/2020 3:11:25 PM • Proform XP... • Answered on Aug 21, 2020
2answers
I have apro/form 620 electric
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics. You should stop using the treadmill AND test the following:1) Mechanical adjustment &Lubrication: http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related http://www.youtube.com/watch?v=dxpOOPetVLo After you did this and the problem persist , you may have electrical and electronic problem go to the next section videos:2nd) electrical and electronic Test:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=relatedhttp://www.youtube.com/watch?v=-oeXTKqWECw&feature=relatedhttp://www.youtube.com/watch?v=GPI6dFJCUA4http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedhttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA sincerely.
2/23/2020 6:18:28 PM • Proform XP... • Answered on Feb 23, 2020
I am either walking or running already for a few minutes and the treadmill part of the treadmill just stops suddenly but computer part still shows all right info. My wife weighs 130lbs. and doesn't h
If the machine is over 7 years old then you need to replace the walking belt. Most proform treadmills are not meant to be run on, especially by anyone over 220lbs. Forget what the manual says, they are a terrible company.
9/13/2017 9:43:47 PM • Proform XP... • Answered on Sep 13, 2017
2answers
Help with lossong weight and then find soul mate
Dear Laura: I can recommend you to follow the instruction of your onwer manual, they have many instruction how to lose weight.Of course the best if you have consult with some expert nutritionist.God bless you
9/15/2016 1:50:28 PM • Proform XP... • Answered on Sep 15, 2016
SIZE+CAPACITY+VOLTAGE of fuse
If you wish to get some details; check the site linked here. Pull up older posts.. http://electro-medical.blogspot.com/
8/9/2016 5:21:12 PM • Proform XP... • Answered on Aug 09, 2016
2answers
When walking on my pro form xp weight loss 620,
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
3/7/2016 2:10:40 PM • Proform XP... • Answered on Mar 07, 2016
I need a manuel for my ProForm 620
Go to iconservice.com click on manual then manufacturer the this M# PETL6201
4/17/2015 10:44:29 AM • Proform XP... • Answered on Apr 17, 2015
2answers
Treadmill control panel not functioning properly
Hi Pstefanski..Afraid there is no easy fix to this problem..I had the same also..I called Sears and for the cost of replacing the keyboard, it would be cheaper to buy a new treadmill..keyboard was close to $300 ..depend how old it is to tellu the truth..AL
3/18/2015 7:06:55 AM • Proform XP... • Answered on Mar 18, 2015
I need to move treadmill Proform XP 650E to another room but the door is small
Have you considered moving the doorway first? Or you could go with what all these other people are suggesting: turn up the speed and then ride it like a tank through the wall. If you have drywall you might slide right through. Please record the whole thing for the rest of us. We all need a good ab workout from laughing at the result. http://www.floridaaesthetics.com/medical-weight-loss
9/24/2014 2:08:41 AM • Proform XP... • Answered on Sep 24, 2014
0answers
0answers
Motor
Be the first to answer 3/23/2014 4:30:43 AM • Proform XP... • Posted on Mar 23, 2014Be the first to answer
0answers
Proform XP Weight Loss 620 Treadmill Logo
158 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
when its switched power light comes but
  • Exercise & Fitness
