20 Most Recent Life Fitness 9100 Next Generation Remanufactured Treadmill Questions & Answers
iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Life Fitness... | Answered on Dec 01, 2014
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
Life Fitness... | Answered on Jun 01, 2014
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Life Fitness... | Answered on Jan 19, 2014
home switch sensor
Life Fitness... | Answered on Nov 05, 2013
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
adjust the REED switch, see the diagram, clean it, test for open or faulty, and tight the connector very well.
However you must RUN the software calibration for easy diagnostic, and fix it. 6c4c6e08-8307-45a9-a0ef-8476bc51f1ff.gif
God bless you
Life Fitness... | Answered on Jul 10, 2013
TrimLine was part of Nautilus until they were phased out Your problem sounds like the lower board is causing the problem. Not knowing where you are located it would be hard to direct you to a servicer near you , but ultimately you will need to call and see if you are comfortable in the way they handle you over the phone. If you are game to repair this the only tool you will need is a phillips screw driver. Unplug the unit pull off motor shroud and you will see a lower electronics board get a pencil and pad make a drawing of board ( stick man drawing good enough) and make notation of where all the connection go to check it twice before disconnecting and usually their are only 4 screws holding the board. Now you may purchase this board Treadmill Doctors.com just them M# and Ser# and they should be able to help you. Good Luck!!
Life Fitness... | Answered on Feb 22, 2013
just bought a amazing model after reding review on this site thanks amazon rock http://www.pianoforall-review.com/life-fitness-treadmill-reviews-does-it-works/
Life Fitness... | Answered on Dec 04, 2012
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Life Fitness... | Answered on Oct 16, 2012
    1_ CPU is SYSCON, is the unit control electronic,that sen all electronical signal to the electronic of equipment.
    2) tight every wires connector very well and clean it
    3) Run the software calibration for diagnose, troubleshooting , fix it
    4) However you must calibrate the REED swith, see the diagram, clean it, and tigh the wires connector very well, exchange the batteries by new ones and clean the contacts cleaner 5) tight the ribbon cables from keypads switch +tight the display board connector vs lower board and proof again.
    God bless you
    Life Fitness... | Answered on Jul 27, 2012
    Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
    Popular Tags
    60 questions posted
    Top Life Fitness Exercise & Fitness Experts
    Vincent_G
    Vincent_G
    Craig Butler
    Craig Butler
    Android Man
    Android Man
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
    View Most Popular
    • Life Fitness Exercise & Fitness
    Most Popular Question
    reset classic 9100hr treadmill after
    • Exercise & Fitness
