Model 40018: You do not need the 9-volt battery to operate this clock.
NO TIME DISPLAYED WHEN PLUGGED INTO AC POWER:
If the display is blank when plugged into the AC outlet, unplug from AC power and remove the Insta-Set battery (lithium button cell), then plug into AC power again and manually set the Time and Date.
HOUR: Press and hold the DST SET button for 7 seconds until the 12:00 flashes. Use the PLUS and MINUS buttons to set the Hour. Press and release the DST button to move to the Minutes.
MINUTES: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Minutes. Press and release the DST SET button to move to the Month.
MONTH:The Month will be flashing. Use the PLUS and MINUS buttons to set the Month. Press and release the DST SET button to move to the Date.
DATE: TheDate will be flashing. Use the PLUS and MINUS buttons to set the Date. Press and release the DST SET button to move to the Year.
YEAR: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Year. Press and release the DST SET button to secure the setting in the memory.
After completing the manual set for time and date, insert a fresh Insta-Set button cell battery and the settings will automatically be stored in the clock.
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen. In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped. In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again. Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again. To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
It depends on the make/model of the set.
All you need is to press and hold and the clock will blink on the hour/minutes and it must be changed and set. Use the button marked clock to press to hold for setting. Change time using the 0-9 key pads by typing the correct time..
Below are the steps to assist you in setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are on the faceplate above the respective key. Position the calculator so that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press the AM/PM accordingly.
4. Firmly press and release the TIME SET key. The first digit should stop blinking and the time is then set. The seconds will again be displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To return to either the TIME or DATE, press the CALENDAR/CLOCK key to toggle between them.
Timer Setting 1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing 2.Press "st/stop" to increase hours; 3. press "mode" to advance to next setting value
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Hold source button till radio turns off and clock turns on. Hold Function till clock blinks. Press arrow keys to select direction of time. Then press Source again. All done
http://www.emersonradio.com/owners Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
1. Press and hold down the ANNOUNCE control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your announcement
and reset to
answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the
desired level.
B. Setting the Voice Time/Day Stamp
1. Press and hold the TIME/REPEAT control for 2 seconds until you hear
"Monday 12:00 AM".
Release the control. Press and hold the On/Off Control until you
hear the correct day.
2. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF
Control until
you hear the correct hour.
3. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF
control until
you hear the correct minute.
4. Press release TIME SET/REPEAT Control. Press and hold ON/OFF Control until
you hear PM.
Press and hold PLAY Control to return to AM.
5. Press and release the TIME SET/REPEAT Control to complete procedure. Unit
will prompt
the day and time.
