20 Most Recent Uniden Cordless Phone Questions & Answers
I CALLED UNIDEN WITH THE SAME PROBLEM.
THE VISUAL RINGER IS FLASHING WHEN YOU HAVE OLD EMAILS. YOU HAVE TO DELETE THE OLD EMAILS
Uniden Cordless... | Answered on Apr 07, 2019
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Uniden Cordless... | Answered on Mar 02, 2019
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Uniden Cordless... | Answered on Feb 28, 2019
    I found the Uniden 2.4GHz XS1410 cordless phone manual on the product page from Uniden Australia: http://www.uniden.com.au/australia/p_xs1410_index.asp. The direct link to the manual is http://www.uniden.com.au/resources_main/pdfs/XS1410_OM.pdf .
    I hope this helps.
    Uniden Cordless... | Answered on Nov 05, 2018
    If I get desperate I open the phone with small screwdriver and pry it open. Undo internal battery replace and if that doesn't work I've reset the brains by clearing inside dust and pressing buttons with screwdriver tip to sort of short circuit and reset the brains! I figure it's not working properly anyway it might ! It did.
    Uniden Cordless... | Answered on Oct 07, 2018
    Check power supply is connected properly at base unit.reseat handset on base to re register the phone.check battery on phone is charged and phone line is live.sometimes units have intercom buttons so see if you can activate the intercom from the base unit to see if base talks to handset.
    Uniden Cordless... | Answered on Aug 20, 2018
    El telefono suena una alarma desde la base durante un minuto. Para silenciarlo no responde a ningun comando. El problema es que lo tengo en modo silencio usando # por nueve horas y la alarma se dispara a las 2: 16 am.
    Favor envieme algun procedimiento para silenciar.
    Funciono sin problemas durante un mes.
    Uniden Cordless... | Answered on Jul 20, 2018
    Reasonable price depends on the person buying something. When I have purchased replacement batteries for a cordless phone I have gone to Radio Shack or Best Buy. Now depending on the age of the phone, you might be better off buying a new phone rather then replacing the battery, because some of the batteries can run almost as much as a new phone.
    Uniden Cordless... | Answered on Jun 20, 2018
    Try Googling (ge)(25899ge3-a)(manual) without parens to get instructions.
    Uniden Cordless... | Answered on Feb 18, 2018
    Go to the manufactures' website for help.If you can't do it from the menu
    Uniden Cordless... | Answered on Feb 02, 2018
    Uniden Cordless Phone Logo
    4,849 questions posted
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
    View Most Popular
    Uniden Lands Phones
    • Uniden Lands Phones
    Most Popular Question
    blocking phone number
    • Lands Phones
