The screen being green on your TV is either caused by a loose or damaged cable connection of a media component to or from the TV or it could be that the TV's T con board is having problems and it would be more cheaper to bu a new TV than to try and fix the one that you have is broken.
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set. If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
Fresh Contrast: Off
Noise Reduction: Medium
Gamma: Medium
Black Level: Low
Real Cinema: On
TruMotion: Low
Color Standard: HD (N/A w/HDMI)
White Balance: Warm
**Method: 10-Point IRE
10 IRE
**Red: 1
**Green: 2
**Blue: -16
20 IRE
**Red: -6
**Green: 0
**Blue: -7
30 IRE
**Red: -5
**Green: 0
**Blue: -4
40 IRE
**Red: -8
**Green: 0
**Blue: -4
50 IRE
**Red: -4
**Green: 4
**Blue: -4
60 IRE
**Red: -6
**Green: 6
**Blue: -5
70 IRE
**Red: -8
**Green: 3
**Blue: -10
80 IRE
**Red: -8
**Green: 7
**Blue: -16
90 IRE
**Red: -9
**Green: 5
**Blue: -18
100 IRE
**Red: -10
**Green: 4
**Blue: -9
Color Management System
Red Color: 0
Red Tint: 0
Green Color: 0
Green Tint: -15
Blue Color: 0
Blue Tint: 11
Yellow Color: 15
Yellow Tint: 2
Cyan Color: -15
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it. im isf certified those settings are right on the money straighter than a ruler
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
