20 Most Recent
Hitachi 50UX57B 50" Rear Projection Television Questions & Answers
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
HITACHI 52"PROJECTION TV WITH BAD
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Large Black Box Showing up in middle of screen.
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
How to remove c707
C707 is just a simple capacitor that is very easy to remove. If you are askign this question it sounds like you are realy winging it which is never a good idea. You may want to instead get a complete repair kit from
www.tvrepairkits.com for this model. It will include the parts but more importantly in you case the instructions on how to do the repair from start to finish
Lines flickering verticaly thru screen
l would check to see on a rear input (audio/video) if this happens and if using a coax connection wiggle the cables with set on and doing this--a poor shield connection on a coax cable will do this also.Trying the rear input will rule things out and may offer a way around the issue.
How to take hitachi 51 projection tv lense apart?
Don't try that if you are talking about one of the three lens, very easy to open the wrong way and have the Glycol come out all over the place and it is toxic.I know these sets well--just let me first know what the set is doing and not doing!
