20 Most Recent Sony KP-51WS500 51" Rear Projection Television Questions & Answers
Please do't do anything. Just let it dry completely, preferably in the sun. Do'nt switch it on before it is dry.
Sony KP-51WS500... | Answered on Oct 17, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony KP-51WS500... | Answered on Sep 11, 2017
OTHER THAN TRYING IT IN THE CUSTOMER MENU there is the tech menu.
With the set off on the original Sony remote control press:
Display, 5, Vol up and power.
The set should come on with a lot of words and numbers on screen.
With 1 OR 4 you navigate until you see PJE on the screen.
9, and then 6 on the remote will bring up the convergence grid. You will see a grid with a blinking colored cursor--if it is green do nothing--3 will allow you to change to red or blue or green. IT IS A GOOD IDEA TO CHANGE THE SET TO A UNUSED VIDEO INPUT TO MAKE IT EASY TO SEE WHAT YOU ARE DOING.
Select red with the three button and navigate with the 1 or 4 buttons--enter button will allow you to adjust. enter again will allow you to navigate with the 1 or 4 buttons-- you want to get to the middle of the screen and then with 1 or 4 buttons navigate from the center around the screen.
You will find 1 moves adjustment in one direction and 4 in another. Go all around and adjust red first. Then repeat with blue.
YOU ACTUALLY ADJUST USING THE CURSOR BUTTONS--WHEEL NEAR THE MIDDLE OF THE REMOTE--YOU WILL SEE THE CHANGES AS YOU DO THIS.
When you are done hit Muting and then enter to save adjustments.
NOTE: some of these sets require the convergence be adjusted in the 4X3 which will also adjust in the FULL--if the set has the ZOOM AND WIDE zoom you will have to repeat the adjustment again in one of those modes to adjust Zoom and Wide Zoom.
Also if you have HD connection you may have to adjust it there also--many of these sets require it to be adjusted 3 times in the three modes.
IF convergence will not adjust in any one of the picture modes you have a convergence circuit problem and need to replace the convergence chips etc.
When you are done be sure to hit Muting and then Enter to save adjustments you have made. The word Write will appear on screen in green when you press muting and then in green when you press enter--it means you have saved the adjustments.
NEVER TRY TO ADJUST GREEN!
If you have questions or need help let me know.
IF this information has helped you rate this solution as I do this here for free.
SD TECH
Sony KP-51WS500... | Answered on May 26, 2015
You have all three projection tubes that are failing. This was a common issue for this year. Depending on serial number 2 of the 3 CRT's (green and blue) are no longer available. They will have to be pulled and rebuilt.
Sony KP-51WS500... | Answered on Apr 29, 2015
yes....call repairperson..
Required D board part number for KP-51WS500 is appended below:
A1300417A... D COMPLETE BOARD
Available in Part Store, click the link for price info.
Thanks.
Sony KP-51WS500... | Answered on Apr 27, 2015
the remote transmitter can be found at the following web site:
http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=RM-Y909
$24.95
you might also have bad convergence ICs, or connections to the ICs, & possibly open fuses to those ICs.
Sony KP-51WS500... | Answered on Mar 04, 2015
A switching regulator is a bit of electronic circuitry that regulates the voltage conversion on a switching power supply, Modern TV sets have switching powers supplies that converts the 120V AC to DC voltages that drives the circuits. You may have to replace the power supply.
Sony KP-51WS500... | Answered on Jun 26, 2014
Check PS8001 to PS8006 Pico fuses all 3.15amp on the D board,
also check PS5001 and PS5002 on the G board 5 amp Pico fuse
Sony KP-51WS500... | Answered on Jun 06, 2014
Sony KP-51WS500 51" Rear Projection Television Logo
533 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
mi television la prendo y
  • Televison & Video
