20 Most Recent
Sony FD Trinitron WEGA KV-27FS100 27" TV Questions & Answers
SONY FD Trinitron Malfunction
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase
" my service table today "
in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
5/13/2017 2:49:51 PM •
Sony FD...
Answered
on May 13, 2017
Sony kv27fs100
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
9/10/2015 11:04:30 AM •
Sony FD...
Answered
on Sep 10, 2015
My Sony Trinitron televison, model
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/4/2015 12:34:28 PM •
Sony FD...
Answered
on Mar 04, 2015
How do i get on netflix
You would need to plug it into a computer or "smart" device. Many blue ray players have such capability and there are countless add on boxes, I use a sony n200 myself since it has composit out.
2/1/2015 4:31:42 AM •
Sony FD...
Answered
on Feb 01, 2015
I have a sony triniton
hi, code 5 in sony tv is indicates of a weak screen,which is too expensive to replace.
some times it helps to lower the brightness of the screen.by adjusting the button on
the flay back, the part that connect with wire to the top of the screen.good luck!
10/4/2014 10:14:55 AM •
Sony FD...
Answered
on Oct 04, 2014
