Lthe water runs into tub but doesn;t fill to begin washing cycle? Every now and then the wash cycle will start and finsh other times it finishes the washing cycle but does the same thing during the rinse cycle. And there are times when it completely finishes a full cycle. start machine water runs it will not fill it just gose out the drain
Be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
water will not turn completely off after wash cycle is complete. small amount of water keeps running into drum from dispenser. I have to run a drain cycle to keep it from over flowing onto floor. If i do not keep eye on it constantly it will flood the laundry room.
