Computers & Internet Logo
Anonymous Posted on Dec 31, 2012
Acer aspire not working
Acer aspire pc not working? When i start the pc i heard 4 short beep sequence (beep beep beep beep no pause) The pc's fans are working and the pc is on, but no response is given by the pc, nothing showing in my monitor, mouse and keyboard don't work. PS: Iv'e checked the monitor, mouse and keyboard, and they work fine. What is the problem?
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Dec 31, 2012
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1557312
Points
18452
You can try to open your computer then remove the RAM then use a pencil with eraser to clean the gold teeth and then put the RAM back and test it out.
5 Related Answers
Anonymous
  • 1913 Answers
  • Posted on Nov 24, 2008
SOURCE: Acer AM5641 Desk-top PC
when u power up the computer u heared any beep check then num lock if u abkle to num lock on and off your cpu is ok.then tv to cpu connection we have to check.
also press F8 key when u power the cpu then go to enable vga mode.
then change resolution to 800*600 or 1024 *768
Anonymous
  • Posted on Nov 27, 2008
SOURCE: My Keyboard and mouse stoped
I need more details.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jun 28, 2009
SOURCE: Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Anonymous
  • 2229 Answers
  • Posted on Nov 05, 2009
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
tecnomage201
Robert Stout
  • 222 Answers
  • Posted on Apr 29, 2010
SOURCE: 3 medium beeps on pc; repeating
According to Systemax, the problem is solved by removing the video card, then the RAM, followed by installing the RAM in the first slots (0 & 1) then reinstalling the video card.
They say the components are too close together and can be slightly off-set if not installed in that order.
Good luck.
The only other idea is the BIOS battery is dead.
1helpful
Aspire 9412awsmi wont start
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. 3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. 4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
1helpful
6answers
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Acer aspire z5700 wont come on
1 long, 1 short beep : System board problem
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive I SATA
My computer beeps when I start it up how do I stop it
The beeps you hear are BIOS Beep Codes. The computer's method of telling you something is wrong, and an area to look into for it.
It is a pattern. A series of beeps, then a pause, then a repeat.
It is a Code.
http://www.pchell.com/hardware/beepcodes.shtml
Listen to the beep code. Post it back in a Comment.
Regards,
joecoolvette
6helpful
3answers
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
2helpful
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
1helpful
4answers
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
One long and two short beeps while starting
hi
this may be ur ram problem so get the ram of more memory
Grand Canyon Tech
Grand Canyon Tech
