How do i setup belkin f7d3402 as a wireless access point?
SOURCE: Belkin F5D5231-4 - create a wireless access point
I have had good luck with the NetGear Rangemax WPN824. It has multiple
antennas that are supposed to provide better range, and your kids will
like the blue blinking lights.
http://www.netgear.com/Products/RoutersandGateways/RangeMaxWirelessRoutersandGateways.aspx
Nintendo has a list of incompatible wireless routers:
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterIncompatible.jsp
and the Rangemax is not incompatible.
Wii can use 802.11B or G.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterChoose.jsp
Since the Rangemax is both a wireless access point and a router (with 4
ethernet ports), you can just replace your existing router rather than
plugging this router into your other one.
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: how can i connect my
Your PSP does not support the WPS feature on the Belkin router. The solution is to turn WPS off. WPS can be disabled in the configuration program for your router.
You do not need WPS it is simply a protocol to make conection to some modern devices simpler.
