20 Most Recent Belkin F5D7130 And F5D7010 (Bundle) 802.11g/b (f5d7130/f5d7010) Questions & Answers
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Belkin F5D7130... | Answered on Feb 21, 2011
You can download the manual and quick instalation guide for the F5D7130 Wireless Network Access Point
from Belkin. No software is needed nor is supplied with the access point.
If you bought the access point bundled with the network card F5D7010, then the disk that came with it would have the drivers for the card. You can get them from Belkin also. Click here
Belkin F5D7130... | Answered on Dec 19, 2009
ok maybe try rebooting the system to mange the router try going to do the same thing to help out trying to manage the display now
Belkin F5D7130... | Answered on Jul 29, 2009
only thing thats worth trying is hold the reset button on the router in for 10 secs. see if it makes any difference. you could install a new firmware but not likely to make much difference for that kinda fault.. John
Belkin F5D7130... | Answered on Feb 26, 2007
OFF THESE FOOLS ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
Belkin Computers... | Answered on Sep 13, 2019
BAD IDEA ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...999OIL
SEE YOU ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
Installing a Belkin extender is Quite Easy With Right Guidance. As you know Extender will help you boost your network strength. Who has an Older Belkin extender Please Reset it Before you go For Installation. Reset Will Also help you to Troubleshoot the Belkin extender Problems & Allows you to make changes to it. After Reset of your extender, You can Setup Belkin extender as you wish. just visit https://bit.ly/2WM0Hik
Belkin Computers... | Answered on Jul 06, 2019
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Belkin Router Support Number In present day time use of web has occurred in a wide range and the life of a human is Rokus work with both Mac and PC PCs, and they can be associated with the two sorts of PCs in a similar manner The Process to Set up a Belkin Router Router. Setting up a Belkin Router is very easy you can either do it by reading the user manual or you can take help by calling on Belkin Router customer service number, you will get 24*7 support from Belkin Router while setting up a Belkin Router Wi-Fi Dial Now Belkin Router Support Number For Immediate Assistance We commit our prosperity to our customer. We are capable of delivering the device and its answers for our clients and keep they're separate private and business clients associated with proficient and fulfilled outcomes Belkin Router Support Number for Belkin Router Support. In modern era usage of internet has taken place in a wide range and the life of a human is rotating in accordance with the internet connectivity. Day-to-day activities cannot be performead without the internet
Belkin Computers... ' Posted 1 minute ago
Belkin Computers... | Answered on Jun 26, 2019
We have enough spam coming from China thanks. We don't need any more!
Belkin Computers... | Answered on Jun 24, 2019
The steps of setting Belkin range extender is the simplest one.
step 1 plug the router to the power outlet and place the extender near to the router or in the range of the router.
step 2 check your computer or phone available network list.
step 3 there is an unsecured network by name of Belkin.setup available.
For further steps, you need to visit https://belkinrangesetup-extender.com/
Belkin Computers... | Answered on Jun 18, 2019
This is the password or passkey that you normally use to connect to your wireless router.
Refer to and follow instructions especially pages 4 and 10 - 12 , 16,17,18, 12 You can use reset to restore back to out the box status.
www.belkin.com/support/dl/MAN_F9K1111v1_8820-01079_RevA00_N300_RangeExtendr (2).pdf
Belkin F5D7130 And F5D7010 (Bundle) 802.11g/b (f5d7130/f5d7010) Logo
Popular Tags
6 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
anyone know get setup
  • Computers & Internet
