20 Most Recent Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Questions & Answers
. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Belkin Wireless... | Answered on Feb 27, 2011
There should be a tiny reset button on the back of it that you can only push with a pen. You may have to hold it for a few seconds.
Belkin Wireless... | Answered on Jan 07, 2011
You can reset the Belkin back to the default settings by powering up the router and press and hold the RESET button on the back of the router for 7 secs.
The router's configuration URL is http://193.168.2.1
and the default password is blank (just press Enter)
Belkin Wireless... | Answered on Feb 04, 2010
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Belkin Wireless... | Answered on Oct 19, 2009
All devices on your network should be assigned an IP address. They need it to be identified on the network. You can try rebooting your router. The wireless on belkin routers can be a bit temperamental. Then try the 360 setup. If you are still coming up blanks, then check your router's DHCP server setting. Make sure that it is turned on. (It is the function that assigns the IP address.) My lat suggestion is to manually assign an address to the 360. Try this only if you are familiar with how IP addresses work. Hope this helps....
Belkin Wireless... | Answered on Sep 03, 2007
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Belkin Wireless... | Answered on Jul 19, 2006
OFF THESE FOOLS ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
Belkin Computers... | Answered on Sep 13, 2019
BAD IDEA ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...999OIL
SEE YOU ****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...
Installing a Belkin extender is Quite Easy With Right Guidance. As you know Extender will help you boost your network strength. Who has an Older Belkin extender Please Reset it Before you go For Installation. Reset Will Also help you to Troubleshoot the Belkin extender Problems & Allows you to make changes to it. After Reset of your extender, You can Setup Belkin extender as you wish. just visit https://bit.ly/2WM0Hik
Belkin Computers... | Answered on Jul 06, 2019
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Belkin Router Support Number In present day time use of web has occurred in a wide range and the life of a human is Rokus work with both Mac and PC PCs, and they can be associated with the two sorts of PCs in a similar manner The Process to Set up a Belkin Router Router. Setting up a Belkin Router is very easy you can either do it by reading the user manual or you can take help by calling on Belkin Router customer service number, you will get 24*7 support from Belkin Router while setting up a Belkin Router Wi-Fi Dial Now Belkin Router Support Number For Immediate Assistance We commit our prosperity to our customer. We are capable of delivering the device and its answers for our clients and keep they're separate private and business clients associated with proficient and fulfilled outcomes Belkin Router Support Number for Belkin Router Support. In modern era usage of internet has taken place in a wide range and the life of a human is rotating in accordance with the internet connectivity. Day-to-day activities cannot be performead without the internet
Belkin Computers... ' Posted 1 minute ago
Belkin Computers... | Answered on Jun 26, 2019
We have enough spam coming from China thanks. We don't need any more!
Belkin Computers... | Answered on Jun 24, 2019
The steps of setting Belkin range extender is the simplest one.
step 1 plug the router to the power outlet and place the extender near to the router or in the range of the router.
step 2 check your computer or phone available network list.
step 3 there is an unsecured network by name of Belkin.setup available.
For further steps, you need to visit https://belkinrangesetup-extender.com/
Belkin Computers... | Answered on Jun 18, 2019
This is the password or passkey that you normally use to connect to your wireless router.
Refer to and follow instructions especially pages 4 and 10 - 12 , 16,17,18, 12 You can use reset to restore back to out the box status.
www.belkin.com/support/dl/MAN_F9K1111v1_8820-01079_RevA00_N300_RangeExtendr (2).pdf
Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Logo
12 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
xbox 360 help
  • Computers & Internet
