20 Most Recent
Belkin (F5D72304F5D7000) Router Questions & Answers
What is 54g-LRS mode?
BEWARE SPAM NUMBER +1-800-532-4187 BELOW
In some cases, older 802.11b clients may not be compatible with 54g wireless. These adapters tend to be of lesser design or use older drivers or technology. 54g-LRS (Limited Rate Support) allows these clients to be compatible with the newer 54g technology. Switching to this mode can solve problems that sometimes occur with these clients. If you suspect that you are using a client adapter that falls into this category of adapters, first check with the adapter vendor to see if there is a driver update. If there is no driver update available, switching to 54g-LRS mode may fix your problem. Please note that switching to 54g-LRS mode may decrease 54g performance. It is not recommended you use this mode unless you have a very specific reason to do so. This mode exists only to solve unique problems that may occur with some 802.11b client adapters and is NOT necessary for interoperability of 54g and 802.11b standards.
2/9/2021 1:18:57 PM •
Belkin...
Answered
on Feb 09, 2021
How do I access my Belkin N Router's settings?
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
8/28/2018 10:22:12 AM •
Belkin...
Answered
on Aug 28, 2018
F5d8233 4v3
What is the code that you posted? It is not clear what the issue you are facing is.
10/18/2013 12:08:18 AM •
Belkin...
Answered
on Oct 18, 2013
I bought a belkin and it already has a password on it and i dont know what it is
To reset the Belkin back to the defaultsettings -Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1The default PW = blank (just press Enter)You can now change the default admin password.You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
6/16/2012 9:42:36 AM •
Belkin...
Answered
on Jun 16, 2012
When I type in the
First off, make sure the management IP is indeed 192.168.2.1to do that start > run > cmd > type "ipconfig" and press enter, the Default Gateway's IP address is the router's IP address.second step, ping it. you should get a replay backlastly, if you still cannot open the management page, the issue is probably with your browser, one common reason is a configured proxy server on the browser, remove it.for Internet Explorer: Tools > Internet options > "connections" tab > press "LAN Settings" > uncheck all three checkboxes there.I Hope this helps
6/11/2011 9:19:05 AM •
Belkin...
Answered
on Jun 11, 2011
Belkin
Access your router's setup page by going to 192.168.2.1. Verify the wireless settings set in your router. Take note of the wireless network name or SSID, the type of wireless security enabled and the security key. Configure these wireless settings in your XBOX
2/23/2011 10:45:26 PM •
Belkin...
Answered
on Feb 23, 2011
Forgotten internet password
In order to get your router back to the original settings, you must push
in the reset button (usually on the back of the router) for somewhere
between 10 and 30 seconds depending on the router. You may need a pin or
something small to push in the button, because it can be recessed. Once
you have reset the router, the username and password will be changed to
the defaults, admin and password, respectively. One thing you must
remember is that resetting the router will change all of the router
settings back to the factory settings. This means you will lose all of
the changes you made since you got the router. Make sure to write down
any things you've changed, so you can change them back after the reset.
Also, I recommend updating to the latest firmware after the reset.
There a great article at
General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
2/5/2011 1:53:56 PM •
Belkin...
Answered
on Feb 05, 2011
How do i access my
Hi duke2222171,
For you to access the router page just open a browser then type 192.168.2.1 on the address bar and it will ask you for a username and password.the default username is admin and the password is blank.
Rate me if this works so that i can help others.
Thanks for using Fixya.
1/28/2011 8:45:12 PM •
Belkin...
Answered
on Jan 28, 2011
It wont work
There is a great article at
Working with Windows Wireless Networks
1/21/2011 1:09:48 AM •
Belkin...
Answered
on Jan 21, 2011
I recently got an ipod
WIRELESS ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regard ,
Milan
1/11/2011 4:13:41 AM •
Belkin...
Answered
on Jan 11, 2011
My router stopped working today
Call your internet provider with your account, grab at hand,(if is router from your internet provider)what does appear and what does not appear on your router, maybe its lost it way out.
11/5/2010 8:37:21 PM •
Belkin...
Answered
on Nov 05, 2010
