GE 30 in. JGP328 Gas Cooktop Logo
Posted on Jan 11, 2009
Spark igniter discharging when turned off
The igniter on m 4 year old GE Profile gas cook top continously discharges a lite spark when turned off. I have to unplug it to stop.
Got any ideas?
  • clareabell Feb 02, 2009
    I have the same problem where the ignition will not stop sparking and making an awful sound.I do not know how to unplug the sending unit. I have taken off the knob with the problem but could you describe how to unplug the next unit.  The stove has not been cleaned for over a day, would it be wet still and have the same problem?
Anonymous
Level 1:
  • Contributor 59 Answers
  • Posted on Jan 11, 2009
Anonymous
Contributor
Level 1:
Answers
59
Questions
0
Helped
42710
Points
84
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
  • ruhlhorn Dec 14, 2010
    This worked..... a little too much water got down in there during cleaning and the ignitor started going crazy on its own. Remove the controller knob and get a hair dryer. Point the hair dryer into the hole and hold it there. It took about five minutes before my ignitor stopped freaking out. Try this before calling a repair man!
2helpful
2answers
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
3helpful
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
2helpful
When I try to use my gas cooktop, it makes a loud "pop" sound and has a big electrical spark that smells like fireworks then it flips the breaker.. Any ideas??
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hair
dryer do try it out and be sure there is not and liquid in it and put
electrical plug again to test it. If you still have the same problem, replace
the Spark module with a new one.
Here below you will find the
parts layout of your range for all the help you might need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
6helpful
2answers
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 • GE Cooktops
Ticking sound does not go off even after knob is turned to high or medium
A lot of questions on this site but very few answers. I have the same problem. After an overflow from a pot, the 2 front burners now won't light one rear one lights but won't stop sparking and the littlest one is fine.
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
