20 Most Recent GE 30 in. JGP328 Gas Cooktop Questions & Answers
As to the grates sagging it depends on the manufacture on a recall. Generally when you order the replacement parts unless there has been an enhancement by the man., they will be the same.
be sure not to use high heat for long periods this is what cause metal fatigue.
GE 30 in. JGP328... | Answered on Oct 02, 2017
Hi Howard:
Best resource is your local gas appliance retailer.
GE 30 in. JGP328... | Answered on Nov 24, 2015
There used to be a liquid called Tolulene which dissolved the glue but nowadays its been banned because of many health reasons. I got told by a floor covering Guy that sanding is the only way to do it now. Hire a belt sander for a day and get it all off.
GE 30 in. JGP328... | Answered on Oct 18, 2013
if non of them are sparking, and it use to work, most likely, you need a new spark modual,
GE 30 in. JGP328... | Answered on Apr 22, 2013
I think you are after part number WB02T10461
GE 30 in. JGP328... | Answered on Feb 19, 2011
You could of possible got the stove top wet causing the problem.This problem although sounds like your spark ignitor module went bad.
GE 30 in. JGP328... | Answered on Feb 10, 2011
check the gas inside you must exsorted it so you need to refill it
GE 30 in. JGP328... | Answered on Jan 19, 2011
Somethings when we clean the cooktop with a damp rag especially around the knobs moisture can get onto the burner switches. When this happens it creates a short and spark the electrodes. Try to unplug the unit for 24hrs. I have had so many just dry out and never had a problem. If you try this and still get the clicking change out the wire harness part#WB18T10339. Its a series of switches that sit on top of each burner and connected to the spark module. I would recommend changing out the spark module part#WB13T10046. Both of the parts are only around $20-$30 a piece and you will have your cooktop running like new.
Please look at item numbers 323,318 on the picture thats what needs to be changed out national_a_r.png
Please rate me a "4" if I helped you. Have a super day!
GE 30 in. JGP328... | Answered on Dec 14, 2010
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
GE 30 in. JGP328... | Answered on Dec 02, 2010
Hi, Most of the time when that happens it is because of water getting into the switch behind the knob and shorting it out....give it time to dry out and you will be okay...
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
GE 30 in. JGP328... | Answered on Nov 27, 2010
GE 30 in. JGP328 Gas Cooktop Logo
63 questions posted
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
get up old glued linoleum off hardwood
  • Cooktops
