20 Most Recent
GE 30 in. Profile JGP933 Gas Cooktop Questions & Answers
Remove & replace main top
You should be able to if you have a few tools. First take a few photos as you go so you always know how to put it back together again. Once completed spray around the gas lines with soapy water to check for leaks. Good luck
Ray
5/11/2014 12:25:39 AM •
GE 30 in....
Answered
on May 11, 2014
The valves on my GE
You may have to hold them down whilst turned on to intitise s flame then release the knob the flame should stay on as the fsd has proved to the gas tap there is a flame so will stay on
7/12/2011 11:58:30 PM •
GE 30 in....
Answered
on Jul 12, 2011
Spill water on cook top by gas knobs. now the
Each of the knobs has a little white rotary switch on it's shaft below the cooktop. You've likely got water in one of those switches and it's making the connection in the switch to start the igniter circuit. Unplug/turn off the breaker to the unit. If it's just water and not a sauce or noodle water or something else impure, you may be able to let it dry out without too much trouble. You could try pulling off the knobs and sucking at the openings with a wet/dry vac to try to get more water out of the switches. The worry is corrosion from being wet too long. If it isn't working after drying out, you'll need a new set of switches.
http://www.appliancepartspros.com/part_details.aspx?part_id=3185909
3/16/2011 12:58:45 AM •
GE 30 in....
Answered
on Mar 16, 2011
Glass stove top with enclosed
Hello mfry.... It is true that these glass tops do get more brittle as time goes on and there is the chance that it could break. That said, if the top breaks, you can generally buy a replacement top. I would begin by removing the glass. If it doesn't break on the way out it probably won't break. Once the top is off, then get the replacement ignitor.
If you want to see if these parts are available get the model number and go to the searspartsdirect.com website. Enter your model number and you should get the parts diagrams along with the prices. Joe
Thanks for choosing Fixya!
2/4/2011 1:22:10 AM •
GE 30 in....
Answered
on Feb 04, 2011
