Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
KitchenAid Dishwasher Door Pops open during cycle
KitchenAid KUDS01FLSS5 - For the past 6 months, within a few minutes of cycle start, front door pops open spontaneously. After closing door, it will pop open shortly thereafter. Current remedy is to wedge a door jam between countertop and top of dishwasher door. I hear a popping sound, but door is wedged shut so cycle continues. Issue occurs on all cycles. Door seals look good. Dishwasher is level. Racks fit in properly. Door tension seems a little light (door opens with little force), but is balanced and unchanged from initial installation 3-4 years ago. Any help is greatly appreciated!
  • 14 more comments
  • Anonymous Jan 14, 2009
    I have the same problem. I believe it is the same model as the one you have listed. I need to keep a heavy chair wedged against the door to keep it from opening.
  • ewagatha Jan 19, 2009
    I went ahead and tried bending the latch, up the point where it jsut grazes the inside of the door. Got 15 minutes into the cycle and door popped open again. Thanks for the sugesstion. I'm considering replacing the door latch mechanism altogether...
  • Jan91356 Apr 23, 2009
    I have the IDENTICAL problem am so angry, I paid $900.00 for the Stainless Steel model. Within the warranty period the door was popping open multiple times each washing period. I called Corporate, they sent technition. He ordered parts, was out two time, but it was the SAME flimsy latch, nothing different. It began immediately to pop, and the warranty expired. I called Kitchen Aid, here's what they quoted me. $179.00 for same Parts and Hinge. $15.00 tax, and ((($200.00)))LABOR. That's $395.00 to replace with same defective cheap latch. Bad design. I am so SORRY, I purchased this product. My old Kenmore was installed in 1987, it was a workhorse for over twenty years. Had only 1 service call in two decades. I only replaced it because it was so old and noisey. It worked fine. Kitchen Aid made a bad product design and should replace it with a different machine with a locking latch as the other mfgs use. That's one of the reasons I was reluctant to buy this new product as i noticed the latch was cheaply desgined and not study like the other brands. Shame on Kitchen Aid for this awful design and they won't replace it. Jan R. Tarzana,CA
  • Jan91356 Aug 06, 2012
    Three years of frustration, can't get through a cycle and takes all day to get a complete cycle with multiple door pops and hot moist air escaping. I have to push against the door with my rear end and read a book for the entire cycle!
    Seriously, I'm ready to call a handyman to drill in both sides of wood cabinets, and engineer some sort of movable metal supports, that will mechanically apply firm pressure on each end of the top of door to prevent it from popping. The door will pop, even while empty, and off. Screws are tight, rack is not protruding, all is balanced. The problem is a bad design, horrible, anyone can look that the locking hardware is cheap, threes no firm lock to hold in place. Never will I buy a Kenmore again, and will spread the word that the company is aware of the universal problem and won't take responsibility or recall their defective design. KitchenAid has a arrogant attitude and there should be a class action lawsuit on this issue.
    Model KUDP02CR B8L4
  • Jan91356 May 17, 2013
    Here is my primative, but cheap solution. It works and finishes the cycle. See the green lights after full cycle. Resorting to rubber bands and rubber wedge door stops. I'm the original poster to this issue.
  • Jan King
    Jan King Dec 05, 2013
    Hi, my Kenmore dishwasher would open randomly, and more and more frequently. I had replaced the latch for the 3rd time with no effect. I found pulling on the bottom of the door bent the hinges back a bit and now it no longer pops open.
  • Angel Comas
    Angel Comas Nov 25, 2016
    The door Lach will pop out without removing or disconnecting the dishwasher. A flat tip screwdriver will do the trick by applying force on each of the corner of the door lash. I removed mine , straight it out. Put it back in and it is working again.
  • Rick Bunney
    Rick Bunney Jan 02, 2017
    I fixed this by putting a piece of metal in the latch. See picture below.
  • Bruce
    Bruce Oct 05, 2017
    This fix was spot on! A couple suggestions: If you trim the metal insert to the width of the striker, and glue it in place, it will slide right in without any disassembly. Also, I lowered my dishwasher about 1/2", leaving more space for between the vent at the top of the door and the counter top.
    As my issue started after replacing a burnt out heating element, I suspect that the increased heat contributed to my issue.
    I've replace just about every part of this POS dishwasher! looks nice, but terribly engineered.
    Anyone know the best unit to buy?
  • Anonymous Jan 23, 2018
    Rick Bunney has the best fix, without having to jam external things around the door. This is our third KA dishwasher, and two were bought around the same time, and used in two different houses. Kenmore, Whirlpool, and Kitchenaid uses this same poor design on many models. We never had a problem with the first two, and still using one of them. After the second one went out (after 5 years), we bought another KA, upper end with the three racks. In les than a month, it the door started popping open. Spent a lot of time looking at it, bending the latch, and doing all the other things recommended here, and still an issue. It was worse if there was alot in the top rack, or if you use the hi-temp option or Pro scrub where all the jets are running. No reason to call for service as apparent defect. We did see Rick's solution, and put in the piece of metal on the latch, and then bent it down as far as it would go, and still let the door close. The can feel the difference in the tension of the door when opening and closing, After several full, heavy loads with hi-temp and pro-scrub, it's not opened once. This may not solve the issues of those that have worked OK for along time and needed other parts, but is fixed ours.
  • mohammad pakravan Sep 14, 2018
    This problem will only be solved by aligning the device! My device had this problem and was solved by aligning!
  • Peter Deveaux
    Peter Deveaux Feb 22, 2019
    I had this exact problem. Tried several things before inserting a small thin metal shim under the latch assembly to increase the force it applies to hold the door closed. See photo.
  • William Dossett
    William Dossett Mar 12, 2019
    Yep, that did it for me, perfect, my material was a bit thiner so made it nearly the whole with of the slots on each side so it would stay in place. Door stays FIRMLY shut now. Needed a new thermal fuse $20 - expect to get another 10 years out of this... or at least until we get a new kitchen
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
We had the same problem for the past year. While looking at the dishwasher I noticed the the vent hole is on the left side of the dishwasher (About the size of golf ball and has a grill over it) . The next time we used it we did not load any cups on the top left of the upper rack. We just left one cup space open.
Since we have started doing this it has not popped open. The only thing I can think of is that the cup up against the vent hole kept steam from escaping and built up pressure until the door popped open.
It seems too simple of a solution but we have not had it pop open in over 25 cycles. Certianly worth trying.
Posted on Feb 05, 2009
    New Friend:
I found the problem, there are two grey plastic caps/ plugs on the inside of the tub about an inch in size.They meet the door as it closes to help secure while on. These caps can wear down over time from opening and closing the door.The ones on my dishwasher had flat spots on them.They should be completely round.I replaced them and have not had a problem since, 2 months going strong.You can find the parts online at any of the KitchenAid replacement parts sites.The part# is W10082838.Oh yeah it took me last then a minute to replce them
Good luck,
Anthony
Posted on Feb 01, 2012
    New Friend:
I replaced the latch assembly - did not help. Tried bending the latch hook - did not help.
Noticed that there was too much resistance to the door closing. Pulled off all the rubber gasket that press against the door, cleaned it well, re-installed it and the resistance was gone. Easy permanent fix after wasted time and money. Just do not stretch the gasket as you put it back in.
Paul
Posted on Oct 29, 2010
  • 7 Answers
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Tom
Posted on Jan 14, 2009
  • Gari Normand
    Gari Normand May 03, 2014
    Were you able to retrofit the new latch on your dishwasher?
  • Tom Giardino Aug 28, 2014
    No luck with a retrofit of the door latch. As mentioned above by another poster, we have resorted to leaving the front left cup location empty. This does seem to help but not 100%. The door still pops open. I plan on replacing this diswasher soon and taking it where it belongs.......in the dump!
We have this dishwasher - it worked just fine for 7 years. I must say, tho, that I hate how you can only choose a 4 hour delay. I really would like a one hour delay and an 8 hour delay. I'd actuallly like to choose any hour up to 10, but I would settle for a 1, a 4, and an 8. All the lower end dishwashers do; why can't a high-end KitchenAid? Anyway, I digress. For about the last month (Feb. 2013) the door pops open CONSTANTLY during the cycle. I stand there and close it at least 7 times. What a way to spend your day. We finallyl got a long pole and wedged it under the handle on the front of the dishwasher and the other end of the pole crossed the entire kitchen to rest on the toe kick of a cabinet. Works great! You just have to deal with the ugliness of this look, the stupidity of having to do this to get your appliance to work properly, and the people who are so blind that they trip over the pole. My husband, who did most of the tripping, finally got a couple of widget wedges-itty type things and now we just shove those between the top of the dishwasher and the underside of the countertop. It holds it shut but this is NOT a permanent solution (it probably will be, actually :) ) I don't know what we're going to do because from reading these posts, it sounds like it is not the latch.KitchenAid Dishwasher Door Pops open during cycle - 3_25_2013_3_59_51_pm.jpg
Posted on Mar 25, 2013
  • Jan91356 Apr 09, 2013
    Laughing so loud, I can't believe your photo and what you have to endure. I am the original Poster Jan91356 and just recently someone emailed and provided a wonderful, simple SOLUTION, that WORKS. Home Depot sells those hard rubber Door Stops. I bought Two medium size that came in a package, and another larger one. Take the two smaller ,and Jam under the counter where the metal brackets are in place. One the side jam the larger one near the top. I also braided about 5 very large thick rubber bands together, Open the dishwasher and place one end of rubber band around top left side corner edge of the metal edge while closing the door. Stretch this long band across the front door, and if you have cabient drawers on the right side, lasso the other end of the long string of rubber bands tightly to form a presurre band assisting in keeping the door supported, wrap the other end of lenght around a drawer that opens. I will take a photo and post this silly but effective solution. I still hate KitchenAid for making my life so chronically miserable
  • Cheryl Vozzella
    Cheryl Vozzella Jan 15, 2018
    we use the rubber door stops too!
    New Friend:
After months of having the door pop open multiple times while running and replacing the door latch, the strike plate, the door springs and tension ropes, I finally figured out the problem to our dishwasher. While reading this post, I read about the buildup of scum around the door. So, while cleaning around the door, I realized that when the foldable portion on the top rack was folded down, the door stays shut. When it is folded up for times when washing tall glasses, the door pops open. When the foldable part of the rack is in the up position, the little catch on this part of the rack puts pressure on the door and as the dishwasher ages it causes the door to open. I found that by leaving the rack down or just removing it takes care of the problem. Hope this helps.
Posted on May 13, 2013
  • Brian Thomas Sep 03, 2014
    Update to my previous post: I finally figured out that the upper rack nearest the door had bent slightly from use. I bent the rack in or away from the door about a 1/4 to 1/2 inch giving the door more clearance. I haven't had a problem in over a year. I think the upper rack just gets out of shape from use and needs to be bent back to give the door more clearance. Good Luck.
    New Friend:
We replaced the LINK, DOOR BALANCE & it fixed it. Check the Door & Panel parts manual ~ page 7, part #24, description is on page 8 of this manual. But, in the meantime, my hubby had a HUGE WELTED KNOT on his shin from the door flying open & hitting him while it was running! OUCH!
Posted on Jun 14, 2010
    New Friend:
I have had this problem for several years and have replaced, or had replaced, the latch, door seal, springs, rope etc. Tried the chair and many other makeshift door closers. Finally my repair man (under the extended Kitchenaid warranty), said: Lets try and replace the door hinges. He did this and the DW works like new. No popping in more than 6 months.
Posted on May 10, 2014
    New Friend:
Our dishwasher would stop often and the door would open slightly. I tried replacing the latch but it had no effect. I found by pulling on the bottom of the door (both bottom sides at the same time) while the door is closed, bends the hinges back into the proper position. This finally fixed it for us.
Posted on Dec 05, 2013
  • DaveMcG54
    DaveMcG54 Jan 25, 2016
    Thank you! We've had this problem for years and this is the 1st solution that worked for us. I believe the latching mechanism is very sensitive and there is no one solution for the problem. Since this fix is so quick and easy, I suggest everyone with this problem give this a try.
  • Patricia Regan Geoghegan
    could you please elaborate a little more on how you do this? I am having the same problem.
I have a new twist on this issue. My 120 lb son fell backward and sat down on the open door. It is now noticably lower than 90 degrees when open. Sadly, you have to push it hard to close and it pops open easily by its self. I think i am toast now unless I can figure out a way to bend it back somehow. I was thinking about putting a 2x1 or other object in the openned hinge at the bottom and use the resistance to bend it gentle and a bit at a time until it closes like it used to. I realize that this is risky as the object becomes the fulcrum and I the force I am applying is multiplied by the length of the door - but this is the reverse of what he did to it!
I will let you know how it goes.
Posted on Oct 18, 2009
    New Friend:
I have also been experiencing the same problem with the door popping open during the wash cycle for at least over a year now. One thing I have done that has reduced the frequency of the door popping open is by pushing in the "plastic gray end pieces" on the sliding bars (which go inside the sliding track) on either side of the top rack after the top rack has been pushed in, before the dishwasher is to be started. Also make sure that nothing extends beyond the racks particularly the top one.
Posted on Feb 15, 2010
    New Friend:
Besides all the problem with the door balancer ( I have installed 4 sets) and the problematic key pad and the door opening on its own recently which you all eluded to I have decided to use the stainless steel piece of _ h _ t as a boat anchor. Bosh is next purchase for me. Hopefully someone from Whirpool or Kitchenaid reads this and at least apologies to any one who owns their prized dishwasher anyone need door balances I purchased a few extra pieces of those sill string impregnated in plastic.
Posted on Aug 05, 2013
  • Lacey Marie
    Lacey Marie Apr 15, 2014
    My Bosch dishwasher has the same problem...
    New Friend:
Hi These posts were very helpful so i wanted to add my experience. After reading many posts and repair ideas, replacing the latch, removing the 12 screws to access the latch and door panel, trying to adjust the height of th dishwasher legs etc etc...my solution turned out to be quite simple, although it took me forever to figure it out. For me, and i had the same problem as has been described - the dishwasher door would not shut - the problem was the top rack. That is, not the very thin rack at the top but the middle rack if you will. At the very least before you go through many painstaking hours as i did do a little troubleshooting....remove th top rack then try to close the door. I did this and was shocked ( but very happy) when i heard click and the door remained closed. Then at least i knew that the presuure against the door from the top rack was not allowing the door to stay closed. I simply cleaned out the tracks of the rack and made sure it was rolling all the way to the back and was surprised again when it worked!
Posted on Apr 09, 2013
    New Friend:
I had one of these in my garage http://www.woodcraft.com/Product/2080244/28851/6-x-3-Bessey-EZS-One-Handed-Bar-Clamp.aspx
I clamp it to the countertop just above my $900 dishwasher to keep the door closed - problem.....solved.....?
Posted on Apr 26, 2011
    New Friend:
We just bought a new latch and striker -new part numbers made me think maybe they redesigned the latch - NO, just new numbers, otherwise exactly the same.
My son noticed there are two holes in the latch that align with two threaded holes in the door... but no screws. We're wondering of by adding two screws the latch stabilizes and prevents release.
Any ideas? Otherwise we'll continue with jamming something under the door handle.
Latch Old Number - 8270175
Striker Old Number - 8269426
Latch New Number - 8193830
Striker New Number - 857415
Thanks!
Posted on Dec 16, 2009
    New Friend:
  • 70 Answers
Sounds like a spray wand has become unbalanced. The motion (shaking) vibrates the latch causing the release. This may be an issue for KitchenAid repair.
Posted on May 03, 2017
    New Friend:
Check your door tension. We were using a broom to hold the door closed for a few weeks. Then it finally stopped and there was a horrible noise on the lower left side of the door when opening and closing. The tension rope had broken. I am guessing that it was loose and not holding the door closed with enough tension prior to total failure and that was what was causing the door to pop open mid cycle. TO FIX: Once the dishwasher is pulled out, there are two springs and strings that loop over a figure 8. One of mine was broken at the top and not holding in position. See the attached photo of the kit I used. The broken piece was a small nub of white plastic that fit in the metal dishwasher shell. Not terrible to do.
KitchenAid Dishwasher Door Pops open during cycle - kitchenaid-dishwasher-door-pops-open-oszkeq1t00qkuztunlmt4jg3-2-1.jpg
Posted on Mar 09, 2016
    New Friend:
5 years later and post still going.
Anyway, did what everyone suggested:
1. Tightened door screws
2. Removed never used stemware racks
3. Bent latch bar down
4, Checked steam port
5. Trimmed off excess and then removed door gasket, cleaned it & reinstalled
6. Checked grey dome plugs covering mounting screws. (unworn)
Seems to be working and no door pops yet.
I think #5 was the main solution.
Posted on Jun 23, 2015
    New Friend:
Read all the posts. Did a series of things. 1- tightened the door skin screws with a hex wrench. Top two where latch was were most loose. I was gentle per the post so as not to strip. 2-swapped out the two grey plugs on right/left side. They were still rounded and not flattened as one post had said. 3-I cleaned the gasket gently. 4-I bent lock bad gently down. SO FAR.... SO GOOD! Running a cycle now and no popping open. Total time-20 mins. Cost - $0.00. No popping door open=priceless!
Posted on Apr 21, 2015
    New Friend:
    Problem Solver:
  • 15 Answers
Our problem seems to be focused on the strike plate portion of the door latch unit. Using a thin flat-head screw driver, I pressed down on each tab on top of the strike plate and then the plate slid out easily. Comparing ours to photos of a new strike plate online, I could see there was a curve in the metal tongue that shouldn't be. I straightened the curve out and replaced the strike plate. Now the plate no longer lined up with the door latch. I removed the strike plate again and then adjusted the angle between the tongue and the strike plate. I reinstalled and this time it works well. The door shuts much more firmly (I can feel it latch).
Posted on Feb 25, 2015
    New Friend:
Great to have all the input. In our case (Kenmore Elite), we had tried a new spring kit to rebalance the doors (which was needed anyway) a new latch assembly (waste of money), cleaning the door seal (waste of time), door screws (no change).
Ultimately it was the top rack - thanks to the first poster. We had it in the highest position, and there was a definite slope forward. As you close the door, moving the rack fully back, the door closes. During the cycle, and vibration, the rack slowly crept forward (as it is not level) and pops the door open.
Yes, I suspect that getting the latch "as good as it will go" may mitigate the issue, but ultimately if there's enough weight and slope in the top rack it will push the door open.
We simply adjusted the top rack to the bottom, and it instantly became level. No more popping open.
Easy enough to try - I'd recommend that you try this first.
(I suppose a new, top rack assembly might not have a forward slope to it, and might be closer to level. However it appears that over time it tends to tilt forward, towards the door.)
Posted on Jan 08, 2015
  • robtoe
    robtoe Mar 16, 2015
    I thought I'd follow up as it turns out the "top rack sliding" was only a
  • robtoe
    robtoe Mar 16, 2015
    temporary fix. I wound up adjusting the metal latch a few times, and ultimately found a shape that gave good grip on the door, and we've been fine for about 10 washes so far.
    New Friend:
All of these tips were helpful. I found that a combination of the above actions help to resolve the problem. Most impactful were tightening all of the door screws and pulling up hard on the bottom of the closed door which seems to have tweaked the hinges in the right direction.
Posted on Sep 02, 2014
    New Friend:
  • 3 Answers
Same problem here and I think these doors are very touchy. There have been several causes and several solutions. These most severe seem to result from broken door links which bends the hinges. I have had some success with raising the washer up as high as it can go. I may replace the hinges in the future.
Posted on Jun 01, 2014
I am a original Poster Jan91356, 4-2009 and recently someone emailed and provided a wonderful, simple SOLUTION, that WORKS. Home Depot sells those hard rubber Door Stops. I bought Two medium size that came in a package, and another larger one. Take the two smaller ,and Jam under the counter where the metal brackets are in place. One the side jam the larger one near the top. I also braided about 5 very large thick rubber bands together, Open the dishwasher and place one end of rubber band around top left side corner edge of the metal edge while closing the door. Stretch this long band across the front door, and if you have cabinet drawers on the right side, lasso the other end of the long string of rubber bands tightly to form a pressure band assisting in keeping the door supported, wrap the other end of length around a drawer that opens. I will take a photo and post this silly but effective solution. I still hate Kitchen Aid for making my life so chronically miserable.
    New Friend:
I think a lot of these problems with the door popping open is actually caused not by the door latch, but bent door hinges. I had a similar situation which the door balances on both sides snapped and the door crashed open several times. After replacing the door balances the door was slightly harder to shut closed and I noticed the door sagged slightly down. I replaced the door strike and latch since that was the most common solution to the problem (per this fixya thread) and like everyone that didn't fix my problem. While the new latch sounded like it was closing properly the door would pop open during mid cycle. It was not until I took apart the door to inspect the hinges, did I finally find the root cause of the problem which were bent door hinges. i believe due to the weight of the door and it crashing several times open did it bend the hinges so that the door would not close flush. I put the hinges in a table vise and bent the back to square, put them back in and that finally fixed the door popping open problem.
Posted on Mar 11, 2013
    New Friend:
I had the same problem with this model. I found that there was soap buildup and hard water scale at the bottom of the door on the inside. Once I thoroughly cleaned the area at the bottom of the door on the inside, it has worked perfectly. Apparently the buildup at the inside bottom keeps the door from fully closing and allows it to open while it is operating.
Posted on Feb 24, 2013
KitchenAid KUDS01FLSS2 dishwasher door pops open during the wash cycle which stops the machine. This has been a chronic problem for many months. I did not change the latch assembly as has been suggested by an online parts supplier because I wanted to try some other suggestions as previously been written about in this FixYa web site service.
THE PROBLEM NOW SEEMS TO BE SOLVED! At least, after 4 wash cycles, the door has not popped open and stopped the cycle. What I did was to slide the washer out of the cabinet about half way and adjusted the front legs to raise the front end of the washer about 1/4 to 3/8 inches HIGHER. Then I used a small carpenter's level to make sure that the front end of the washer was level with respect to the floor. That was OK so no further leveling adjustments were necessary. Then I cleaned the rubber door seal of any accumulated debris that had not been rinsed out earlier. Then, I checked all of the TORX screws that hold the interior stainless steel skin to the door frame and I FOUND THEM LOOSE, especially those near the bottom of the door (nearer the hinges). I tightened them all except the two at the top that were still snuggly tightened. Finally, when I removed the two wood screws from the two small brackets that attach the dishwasher to the countertop, I discovered that the installer had only correctly installed one bracket to the dishwasher. These brackets are made to slip into a slot on the top frame of the dishwasher and secured in place by bending the sheet metal tabs at the end of the brackets so that they stay in place. So,because of the installer's mistake or oversight, that one bracket had slipped out of its slot on the frame and was doing nothing to firmly attach the dishwasher to the countertop (an absolutely necessary installation requirement). The other bracket was also not firmly attached to the countertop because a very short wood screw was used to attach it to the countertop wood frame and it had loosened considerably. I had to secure both brackets correctly to the dishwasher and I replaced the short wood screws by using wood screws that were about three times the length that were used by the installer. Since the brackets each have three screw holes, I also added an additional long wood screw to each side to insure a very firm and durable bracket attachments to the countertop wooden frame. Now, the dishwasher seems to be working OK but when we need to replace it someday, I will be shopping for one that has an old-fashioned positive mechanical locking handle on the door. In the meantime, I must remember to check all of those TORX screws and the countertop attaching brackets once-in-a-while.
This KitchenAid dishwasher was the most expensive top-of-line model available 7 years ago and has been a pain-in-the-*** for me since we bought it. We replaced an older KitchenAid that served us well for 25 years that had the mechanical door lock but was making a little more noise during the cycle compared to the newer ones that our neighbors and friends had gotten before we bought the new machine. I wish that we could still be using the old machine now.
Posted on May 19, 2012
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
We had this problem after a serviceman showed us how to lower the front end of the rack, using the top rack adjusters, to accommodate taller things in front. The door started popping open shortly after start-up and then a few times during any cycle. With the upper rack in this position, it is slightly front heavy and puts pressure on the door causing it to open. When we leveled the upper rack, problem was solved. We use the dishwasher about twice a week so it was a few weeks before we made the connection. But, since we "fixed" the rack, problem gone. I can set the machine with the 4 hour delay again.
Posted on Apr 07, 2012
    New Friend:
I had similar problem with door popping open in drying cycle. After careful analysis, I discovered the front part of the upper rack where the handle is to pull rack out was bowed out slightly. The clearance between the face of the rack and the door is very small. In my case it was almost touching the door. When the washer went into drying cycle, the heat would expand the metal rack and it would push on the door until it popped open. I simply bent the front of the upper rack back to it's normal position. The problem went away and the unit has worked great now for over a year.
Hope this helps!
Path~
Posted on Sep 22, 2011
    New Friend:
I have replaced the link door balance, springs, hinges, and latch. We always tighten door frame screws. For the first time in over a year our $900 dishwasher ran one complete cycle. On the second wash, the dishwasher ran for 10 minutes and the door popped. I am so frustrated.
Posted on Sep 07, 2011
  • patrick Hahn Sep 22, 2011
    had similar problem. After careful analysis, I discovered the front part of the upper rack where the handle is to pull rack out was bowed out slightly. The clearance between the face of the rack and the door is very small. In my cast it was almost touching the door. When the washer went into drying cycle, the heat would expande the metal rack and it would push on the door until it popped open. I simply bent the front of the upper rack back to it's normal position. The problem went away and the unit has work great now for over a year.
    Hope this helps!
    Path~
    New Friend:
DIsherwasher wont cycle, I held the cancel button 10 sec. and then tried again. There is a constant clicking in the control panel tho
Posted on Jul 26, 2011
    New Friend:
We recently had to replace both sides of the door balance spring/latch... only to find then that the door would still pop open slightly. We tried bending the metal latch down to help but it didnt work. We ended up wedging a thick toothpick (acutally it's a thick souvlaki stick) in the latch to help keep the latch pressing down. So far.... it seems to work.
Also... we tried giving those inner screws and extra turn to two and that seems to help a little. Not sure what the permanent solution woudl be,
Posted on Jul 25, 2010
SOURCE:
Kitchenaid D/W will not start, lights not all working, getting power. What's my problem?
Sylvia.....is the clean light flashing or any other for that matter? Either way it sounds like the control board is locked up. There are many posts on here about how to reset it. Try the following: With the door open:
Push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry (all the lights should light up) then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. This will unlock the control board and you should be able to restart the dishwasher. There are many issues with this Kitchenaid including the door popping open during cycle issue. I have dealt with all of them over the past 8 years of ownership. Finally replaced it with a used Miele and sold the KA on craigslist with full disclosure of all the issues and it's history. I even threw in the rubber door stopper that we resorted to using to keep the door closed. Let us know if the above procedure works for you. Good Luck.
Nov 30, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Kitchenade Dishwasher. Door keeps popping open during cycle. replaced both the springs and cable in door. door locks but then pops open during cycle.
Try adjusting the door catch, this is the hook that comes out from the top of the machine and clips into the door switch when closed, it can be adjusted further out by loosening the screw. If not then you may need to replace the door switch. This is done by unscrewing th front panel and removing it. The switch is held on by 2 screws and 2 wires. Hope this helps.
Mar 02, 2011 | Dishwashers
During a drying cycle, the whirlpool duet dryer door pops open, the indicators are flashing and even if I close and restart the cycle, the door pops open every few minutes.
This was a concern on some whirlpool and kenmore dryers. The fix was to replace both of the catches (the part on the dryer front panel ) and the latches (the part on the door) as well as a redesigned door gasket. Im sure if you contact Whirlpool customer assistance they would be able to supply you with a part number for the repair kit....
Sep 10, 2010 | Dryers
KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
May 27, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
The dishwasher door keeps popping open
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kithenaid dishwasher door pops open
Your door latch may just be getting weak and the temperature and air pressure differentiation when the cycle is complete (it's hot inside) may be popping the door. If you have had the door seal replaced recently that may also be a factor, they can take awhile to settle in.
Jul 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
28,161 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
