20 Most Recent KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Questions & Answers
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
KitchenAid 24... | Answered on Apr 04, 2018
The cycle timer may have decided to fail.
KitchenAid 24... | Answered on Dec 09, 2017
you should check for food stuck in hose
also check the food chopper assembly (under the bottom spray arm at the very bottom)
if all else fails it may be the pump
KitchenAid 24... | Answered on Sep 04, 2014
Contact service agent or manufacturer.
KitchenAid 24... | Answered on Aug 13, 2014
You need to take out the bottom rack of the dishwasher and disassemble the lower spin arm and filters underneath it. You need to get right down to the chopper blade and disassemble and clean out the chopper blade assembly. Make sure there is nothing buried in the little holes. Once done and you are sure it is clean. Reassemble it all. It should work fine. Having said that.......It will happen again in a few washes until you replace the whole chopper blade assembly.
KitchenAid 24... | Answered on Jul 30, 2014
turn off breaker to it leave one minute and turn back on also make sure door is closed tight and nothing is fouling it from proper closing .
KitchenAid 24... | Answered on Jul 13, 2014
Check thermal fuse on control board
KitchenAid 24... | Answered on Mar 05, 2014
Mfg also advising replacing strike if replacing latch 2cdc165a-a1df-4dfc-9800-484940f3fae1.jpg a9f702c9-7d3c-4809-b739-678e57ad0731.jpg
go to www.applianceart.com
These guys offer many colors and designs to cover all dishwashers. They also have stainless options.
I even found matching refrigerator covers--
KitchenAid 24... | Answered on Nov 20, 2013
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
KitchenAid 24... | Answered on Apr 12, 2013
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
208 questions posted
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
squeaky door
  • Dishwashers
