20 Most Recent KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Questions & Answers
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
KitchenAid 24... | Answered on Mar 29, 2019
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
KitchenAid 24... | Answered on Feb 16, 2019
Stainless Steel are alloys that are made up of iron and generally contain around 11.5% chromium. The addition of chromium allows the alloy to form a protective self-healing oxide film, thereby making them resistant to corrosion and oxidation even at extremely high temperatures. Due to this feature, stainless steel is used for making products across many fields. For obtaining special properties, nickel and other elements can be added to this alloy.
Stainless Steel has excellent resistance to corrosion, protection against corrosion, hygienic material, good strength and ductility, ease of fabrication, ease of maintenance, excellent durability.
Stainless steel is less reactive with foods as compared to other materials.
Therefore, it is used in different industries such as Food industry, Pharmaceutical industry, Petrochemical industry, Automotive industry, Construction industry, Oil and Gas industry, Medical field, Water and sewage systems, Aviation engine components, Nuclear industry.
For more information Click Here
Stainless Steel Flanges Manufacturer Stockiest Supplier
KitchenAid 24... | Answered on Sep 27, 2018
if the light is flashing 7 times there's a heat problem and the dishwasher won't start,if you remove the bottom kick panel you'll see the tech sheet,it will tell you about the flashing error codes, count how many times it flashes and look up the code,if it is 7 times you either have a bad heater or computer board,if you look at diagram it will show you how to read out the heater from board to see if the heater is bad or it's the board.
KitchenAid 24... | Answered on Feb 25, 2018
For KitchenAid Whirlpool KUDS01FLSS0 -- When the clean light is blinking or flashing 7 times in a row and no other front panel controls will work, do the following:
push SaniRinse-EnergySaverDry- SaniRinse - Energy Saver Dry
(Try the Heated Dry button if you don't have a Energy Saver Dry button)
All the lights will then come on as this will put the unit into diagnostic mode.
Then, push Cancel after about 10 seconds. You are no longer locked out. Run the dishwasher normally.
References:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9/$FILE/8178496.pdf
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Clear packing tape is often effective but in a hot wet environment- it is not permanent, you may have to redo. Clean with alcohol swab first.
KitchenAid 24... | Answered on Feb 21, 2018
flashes seven times, it usually indicates a problem with the water temperature.
Go to this site for reset information, if that'll fix it.
http://homeguides.sfgate.com/fix-flashing-clean-light-kenmore-dishwasher-86468.html
hope this helps.
Cheers
KitchenAid 24... | Answered on Feb 17, 2018
Sounds like it could be the bearing in the wash motor. If the sound is only present when you can hear water being thrown around then this would confirm it. Not sure about spares availability on a 7yr old machine though
KitchenAid 24... | Answered on Jan 18, 2018
Kitchenaids have a diagnostic service mode ... but each model can be different on how to activate. The mode is started by sequentially pressing a number of the control buttons repetitively. The particular sequence is usually listed in service technician paperwork within the dishwasher behind the low kick plate in front of the dishwasher.
Or web search "Kitchenaid KUDPO1FL S7 diagnostics" which may help you understand this whole process
Good luck on your troubleshooting
KitchenAid 24... | Answered on Jan 16, 2018
What type of dishwashing detergent are you using. If you use too much or hard desolving detergent you will get a build up that will clog the strainer. Try running some vinegar and water in the washer without the dishes from time to time. That might solve your problem. some stainers are at the bottom of the washer. some are secured by two screws others are twist and pull out. depends on the dishwasher.
KitchenAid 24... | Answered on Dec 12, 2017
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
680 questions posted
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
kitchen aid dishwasher runs about 2
  • Dishwashers
