When using the laptop i have to keep it on charge as if itake the charger out it shuts down like there is no power in the battery even thow it says 100%. when it shuts down it dont go threw the normal shut down stages it just instantly goes off.
SOURCE: Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
SOURCE: HP Pavillion ze2000 loses power
I think the good <a href=http://www.shopgogo.ca/hp/hstnn-c16c.php>Battery fits HP Pavilion DV8000 DV8100 DV8200 laptop battery</a>, and affordable prices
SOURCE: My HP Compaq 6720s keeps freezing
I'd recommend backing up your important files and re-installing windows.
There are soooo many possibilities as what it could be but that's not important. The outcome is what matters. So try that first and then let me know if you have any problems following.
SOURCE: When plugged to AC it charges the battery normally
try a new battery... if that doesn't work take it to a pc repair place...
Iām happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: my hp 6735s shuts down all of its own after 10-15minutes.
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
