20 Most Recent
HP Compaq 6720s Notebook Questions & Answers
Where is the cmos battery located in HP Compaq 6720s Notebook
great question, all HP manuals cover this, for sure older
not the new cheap one with no real manual of any use.
yours is old and has great books,.
here is an echo of the manual.
see see all pages,searched as RTC
its on page 82, found this googling for 1second, work.
using the word Manual added to model
it is own of the 37 screw hard job, coin cell. bottom
ON WRONG SIDE OF MOBO'
16 steps of No fun.
Hi its HP Compaq 6720s originally vista basic and
First, right-click on the desktop where there are no icons and choose Display settings, may be in advanced settings, but look for supported screen resolutions.
If you pick one that is not supported, doing nothing when the screen goes wonky will automatically cause it to revert to what it was before you changed it.
One of the settings there should work for your screen.
If none work, go to your device manager and update the drivers for the display.
How peso sign in word?
- CLICK INSERT BUTTON
- GO TO SYMBOL
- CHOOSE MORE SYMBOL
- SCROLL DOWN THE KEY
- CHOOSE CHARACTER CODE: 20B1
- THEN INSERT IT
I need help i have forgot the power on password
Here I collect some popular solutions to help
reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use
Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
What to do next after upgrading CPU
Hey;
Start your computer and right after the hp logo, keep pressing the F8 button until you see a large list of options.
Select
"USE LAST GOOD KNOWN CONFIGURATION"
and press enter. Let windows load and it should work just fine.
RAM slot not working
Re-soldering a memory slot can be costly. It takes specialized equipment to solder this component and it has to be done right. If you tested the same stick in the two different slots and it fails to boot when the stick is in that one slot, then you have correctly identified a bad memory slot. To be cost efficient, it is propbably beter to change out the main board. There are however companies out there that will repair motherboards regardless of the problem, prices range widely for the standard repair plus parts plus shipping. E-Bay has several companies that advertise these types of repairs.
I have an hp compaq
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Volume controls?
The
quick specs from HP does not show a volume control. Most laptops are designed this way. All volume controls will be located on screen unless you have touch lights across the top of the keyboard, which in that case there would be 3 speaker icons (one is mute, and the others are volume Up/Down).
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
How do I turn off
Hi and Welcome to Fixya
Seems like the number keypad is locked. Press and hold the Fn key then ap the numlock key once. This will disable the number lock.
Thank you and have a good one!
Compac perserio cq71 wont turn on
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
