I have tried connecting optical connection to the TV and then tried the cable box itself. Volume still comes from Sony soundbar remote, not cable remote or TV remote. I tried using code 993 as per GCI cable for volume lock/unlock and neither works. Any ideas how I can get the volume to work from my cable remote
This worked for me, but I have a Comcast Motorola DVD-R:
These are the codes for your SONY SA-CT60 Audio Device. Follow the instructions below to program your remote.
Most likely code: 30158
Others to try: 31758, 31759
To program your Comcast remote:
NOTE: If you would like to program your remote control to work with a DVD Player,
VCR or Audio device press the AUX button.
NOTE: If you enter an invalid code, the red light will display one long blink and
exit the programming mode. Repeat steps 2 to 4 with a valid code.
The 31759 worked with my HT-CT60 soundbar and my Xfinity silver remote. Thank You!
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
SOURCE: We have a new cable box, Scientific Atlanta
sounds like the tv needs to be programmed to variable output on the audio control section in the main menu.
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
SOURCE: Cannot connect my HT-320 home theater to my TV. I
can not get tv sound through speakers---can only get sound from dvd
SOURCE: I have the Sony BDVE770W Theater System and I have
Try sourcing your TV audio from whatever source IT is watching, usually the cable box.
