Screen freezez on startup and fans stay on
SOURCE: Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
SOURCE: broken fan on compaq
don't keep running it until you replace the fan. Look for one on ebay or around the web. It is shutting down because of heat. A $20 fan could cost you your whole laptop if you keep running it.
SOURCE: how to restore to factory settings presario cq50
2 possible solutions to this
1. Use the roll back function of your operating system to roll back to the last back up.
2. Insert your restore disk or Windows disk and do a format/clean install.
If you have a restore disc it will have prompts to "restore" your system and give you a warning about losing data-save off what you want BEFORE doing this restore
If you have standard windows disk you may want to use the format utility in windows first to clean the drive and do a fresh install.
Once installed don't forget to download updates and back up and then reload your other software.
have fun this will take several hours depeneding on the amount of stuff you have to reload and patch up.
SOURCE: The fan of the Presario CQ50 is too noisy. Any
1.replace fan.
2..clean fan [you will have to dismantle laptop or take to shop].
If you clean your fans your self ,always hold fan bladesand dont let them spin as they can back feed and damage your cpu or graphic card. DT.
SOURCE: HP Presario CQ50-130US Bootmgr is missing...
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
