Switch has white (common), black (high), blue (mdeium), and red (low). How do I hook it up to 110?
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
SOURCE: i was trying to install a fan control switch on my
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
