20 Most Recent Patton (HASF1016UC) Stand (Pedestal) Fan Questions & Answers
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Patton... | Answered on Aug 24, 2012
You can use any capacitor of value about 3.3mF to about 6.8mF with an AC voltage rating of about 230 to 250 volts.
These are the bipolar type capacitors and is generrally available at all electrical or electronic spare parts shops.
Hope this helps.
Patton... | Answered on Aug 29, 2010
If you know how (and have the tools;PULLER,nut drivers,slotted and phillips screw driver,hammer,deep socket set,dikes,vise,work bench,and some high temp bearring grease) to take things appart in general, you should be able to disassemble the fan motor and either pull bearings off shaft and replace or repack w/high temp grease if not sealed bearrings. If cannot aquire a puller for removal then attempt to blow all dirt/dust off bearring and try thumbing some motor oil (or vegetable oil if no motor oil available) while turning bearing on shaft back and forth till bearrings free up.Then reassemble electric fan motor reverse disassembly(be sure to keep parts staged as they come off for reassembly in area off the work area) "NOT" over oiling the bearrings into electrical/copper areas.
Patton... | Answered on May 01, 2010
Patton (HASF1016UC) Stand (Pedestal) Fan Logo
30 questions posted
Top Patton Dryers Experts
Tom Chichester
james ayers
Are you a Patton Dryer Expert? Answer questions, earn points and help others
View Most Popular
Patton Dryers
  • Patton Dryers
Most Popular Question
patton floor fan needs switch
  • Dryers
