20 Most Recent Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Questions & Answers
2answers
Harbor breeze ceiling fan without light. I
Power needs to be connected to the black wire. If you only have one fan wire besides the white neutral, connect to one of the switch positions only.
11/26/2017 10:13:29 AM • Westinghouse... • Answered on Nov 26, 2017
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
5/30/2017 12:40:53 AM • Westinghouse... • Answered on May 30, 2017
I have a 3 speed ceiling fan I wired the light but dont know how to connct wires for fan
If the fan only has 2 wires a blue and a white, blue goes to power supply white goes to neutral. Fan switch itself provides the 3 speeds.
8/22/2014 3:44:27 AM • Westinghouse... • Answered on Aug 22, 2014
0answers
0answers
2answers
How do you open a
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
6/29/2013 6:20:33 PM • Westinghouse... • Answered on Jun 29, 2013
3answers
I have a westinghouse three speed fan. there are 4
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
10/11/2012 9:41:37 PM • Westinghouse... • Answered on Oct 11, 2012
Copy following link for wiring 3-speed fan switcheshttp://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/30/2012 10:26:15 AM • Westinghouse... • Answered on Jun 30, 2012
2 speed switch wiring dieagram
The motor will have wiring diagram and voltage on nameplate.You can re-post question with information that shows on nameplate for more exact information, or keep reading below:If motor is rated for 240Volts, then it will not work with 120V.If motor is rated for both 120V and 240V, then either Low voltage or high voltage will work, and one wire will be common, and 1 wire will for 120 and other wire for 240.If motor is rated 120Volt two speed, then one wire will be neutral, and 1 wire low speed, and other wire high speed. You can connect your wire to either low of high, and cap other wire.If motor is 240volt two speed, then one wire will be common, and 1 wire low speed, and other wire high speed.If motor is rated 3-phase, then all three wires are connected to the voltage shown on nameplate.If motor is rated 3-phase two speed, you may need electrician to wire the motor correctly.http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
6/30/2012 7:30:07 AM • Westinghouse... • Answered on Jun 30, 2012
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
52 questions posted
Top Westinghouse Electric Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Electric Electrical Supplies
Most Popular Question
open
  • Electrical Supplies
