20 Most Recent Patton U2-1487 Floor / Box Fan Questions & Answers
You can check with the local hardware store.
Patton U2-1487... | Answered on Jul 03, 2014
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
Patton U2-1487... | Answered on Aug 06, 2012
Hi mlh9188
You can replace your cord that was eaten by your dog very easy.
Disassemble your fan.
Be sure to mark how the fan is assembled with an awl or sharp instrument to scratch an alignment scratch on the outside of the motor case before you disassemble it....maybe even take a picture
Once you have the fan disassembled to the point that you can get to where the wire that was chewed is connected to the fan, you will disconnect the wires from the plugs,sockets,etc...take another picture before disassembly.
Take the old cord with you down to your local hardware store,loews,homedepot,ace hardware,etc.
Tell the person in the electrical dept what happened, and he will fix you up with a new set up.
Come home install the new cord and plug...keep away from dog...
Please take time to rate me
Patton U2-1487... | Answered on Sep 11, 2011
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Patton U2-1487... | Answered on Aug 17, 2011
For Patton fan model U2-1487 120v 60Hz 1.5 amps. the 3-speed switch Patton does not carry replacement parts anymore. I suggest look some aftermark switch and check your wiring and the diagram that come with the switch. You might have the hot wire (power wire usually black in color) wired directly to the motor. Normally the switch will have a common wired which should be the hot wire, then it should have a wire for each speed.
Double check your wiring and wiring diagram. I'm Sure It was just a small oversite.
Personally, I suggest you evaluate the cost-benefit of changing the switch or replace the equipment.
Good luck.
Patton U2-1487... | Answered on Jul 12, 2011
these switches range from 10-20 dollars and are easy to find online search three speed rotary switch in google
Patton U2-1487... | Answered on Jan 01, 2011
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Patton U2-1487 Floor / Box Fan Logo
40 questions posted
Top Patton Dryers Experts
Tom Chichester
james ayers
Are you a Patton Dryer Expert? Answer questions, earn points and help others
View Most Popular
Patton Dryers
  • Patton Dryers
Most Popular Question
wiring 3 speed rotary switch fan cord
  • Dryers
