Pride Jazzy 1103 Ultra Standard Power Chair  Logo
erica garcia Posted on Dec 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got new batteries put into my electric wheelchair but the next day I turned on my wheelchair and the lights just flash and my chair woll not move. do you know what I can do to fix it myself? Please help me!!
  • janbustr May 11, 2010
    Did you charge the batteries after installation.
Susan Nowak
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Feb 14, 2018
Susan Nowak
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
450
Points
How is chair in manual mode?
Anonymous
Level 2:
  • Expert 151 Answers
  • Posted on Dec 28, 2008
Anonymous
Expert
Level 2:
Answers
151
Questions
0
Helped
67374
Points
308
Has the chair been put in "manual mode"? Make sure of this and that batteries are secure.
I recently replaced batteries. now am getting power lights fast flashing and chair will not move after several try;s the chair will turn on
Just recheck your wiring. If there's 2 batteries, then starting from one side....positive to scooter, then neg from this battery linked to pos on next battery, then negative to scooter.
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Chair was charged last night and now the power light flashes and chair will not move
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
1helpful
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
1helpful
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Wheelchair will not move. has 2 wrenches as error
Mr Witaker the 2 flashes follwed by a pause and 2 more flashes etc indicate a battery fault if you have all the battery level lights on the joystick lit up and you are sure the batteries were charged then there is a problem with one of the batteries that the controller doesn't like. try turning the chair off and letting it rest for a while then turn it back on if you still get the two flashes then I would say you need to replace the batteries Now if Medicare purchased your chair they will pay for most of the repair costs you can contact Repair Xpress Tuesday at 1-877-581-3733 to see if they have a tech in your area or call Roadrunner Mobility at 1-800-467-2668 for the techs in your area. Hope this helps
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
3answers
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
