20 Most Recent
Electric Mobility Pronto M41 Power Chair Electric Battery Wheelchair Questions & Answers
I would like to know how toadmust the sencitivity on the wobble stick
You have to have a Invacare Remote Programmer to plug into the joystick and program different sensitivity levels. Sorry, there is no other way to adjust the joystick. Find a store that sells Invacare chairs and see if they can program your joystick. The programmers are expensive to buy and without training with one you could easily cause your chair to really drive bad to not drive at all.
1/25/2015 3:48:35 PM •
Electric...
Answered
on Jan 25, 2015
I purchased a Pronto 41 wheelchair and a Winsunny
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
5/5/2014 4:24:51 AM •
Electric...
Answered
on May 05, 2014
Tips for charging new batteries in Jazzy Select Traveller
Check the charger output to verify whether or not you have a bad charger using a voltmeter. These smaller batteries are notorious for having a short shelf life and poor quality control from the manufacturer. Load test the batteries after you verify you have a working charger that will bring the batteries up to the proper voltage first.
3/6/2014 1:47:11 AM •
Electric...
Answered
on Mar 06, 2014
Catalina powerchair 8 wrench flashes
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
1/19/2014 7:48:04 PM •
Electric...
Answered
on Jan 19, 2014
5 flashes on controler
battery is low, or battery needs to be charged, and if it won't have charger check out.
8/29/2011 4:30:36 AM •
Electric...
Answered
on Aug 29, 2011
Wheelchair will not move. has 2 wrenches as error
Mr Witaker the 2 flashes follwed by a pause and 2 more flashes etc indicate a battery fault if you have all the battery level lights on the joystick lit up and you are sure the batteries were charged then there is a problem with one of the batteries that the controller doesn't like. try turning the chair off and letting it rest for a while then turn it back on if you still get the two flashes then I would say you need to replace the batteries Now if Medicare purchased your chair they will pay for most of the repair costs you can contact Repair Xpress Tuesday at 1-877-581-3733 to see if they have a tech in your area or call Roadrunner Mobility at 1-800-467-2668 for the techs in your area. Hope this helps
9/6/2010 12:08:07 AM •
Electric...
Answered
on Sep 06, 2010
Hello i have a kymco xl mobility scooter which has
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault There is a bad connection to the motor and the controllerIf 's it a Rhino controller normally a blue colour , The battery is completely empty. The scooter does not drive.• Recharge the battery immediately.If the scooter is left off for a few minutes, the battery may recover enoughto allow driving again for a short time. However, driving on an emptybattery may cause damage to the battery.Regardswww.gewizrepairs.co.uk
3/24/2022 8:52:42 AM •
Electric...
Answered
on Mar 24, 2022
Wigwag Throttle Control Pot FREERIDER loose
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
3/25/2019 7:44:39 AM •
Electric...
Answered
on Mar 25, 2019
