Washer runs through first wash cycle then goes to rinse and stalls. I can see water entering chamber but slowly. Makes strange, humming noise at that point too.
Check drain hose under the tub by unscrewing clamps to see if there is any blockage in this pipe; also clean out filter in this area. Disconnect from mains before doing so.
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
when you start the washer set it just on cold and see if it fills slowly,when the washer goes to rinse it just uses cold water,you could have a problem with the washer or in the house,when you run it on just cold and if it dribbles in,stop it shut down the water going to the washer,remove the cold water hose from the back of the washer,stick it in the sink or inside the washer and turn it on,if it comes out strong then you have a bad water valve on the washer,if it comes out slowly you have a bad water valve in the house and it's not the washer.hope this helps
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
It sounds like a siphon issue. Check
that the drain hose does a high loop before it goes into the drain
pipe. (ie. drain hose loops above the water level inside the tub). Make
sure the drain hose is not pushed too far down into the drain pipe.
Also if the drain hose is sealed to the drain pipe this will create an
airlock and a siphon will occur, allow air to enter between drain hose
and drain pipe connection. This should help you but if there is still a problem let me know and I'll try to assist you further. Good luck!
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
