It is an Inglis dryer. Not sure what model number. I was about 10 min. into the drying cycle when the buzzer went off longer then when it buzzes when it is done. There was about 50 min of drying left on the timer. It wont turn on. The only thing that works is the timer moves. I checked the braker at the electrical box. I turned the braker off then on. Still nothing. I was using the dryer a lot for 2 days before it quit. Need help please. I have six kids and the cloths are piling up. Raining today so I can't hang cloths on line.
SOURCE: dryer suddenly quit working
Having the same problem as above. Worked uptill yesterday. Now lights come on no activity. Please Help!!!
SOURCE: Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
SOURCE: Maytag Performa Electric Dryer Won't Start
Replace the thermal fuse and the high limit switch.
They come as a set.
Clean the auto dry sensor with rubbing alcohol.
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
SOURCE: My whirlpool heavy duty dryer just quit working all of a sudden
make sure you are getting power first then check to see if the belt is broken
Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
