20 Most Recent Whirlpool Inglis IP8200 Dryer Questions & Answers
Have a part here I need identified..How do I upload a pic?
Strange, I answered this earlier. I changed the category as well and that stuck but no text and image I added.. Yes you can. click Photos, Click upload, navigate to where the image is, click Open. we will also need the model. some help here.https://www.google.com/search?q=Inglis+gas+dryer+Thermal+fuse.
3/18/2022 11:25:47 PM • Whirlpool Inglis... • Answered on Mar 18, 2022
My Whirlpool Inglis Model IED4400SQ0
this doesn't have a board in it so you either have a bad timer or motor,i would think it would be the timer,try tapping on the timer with a screw driver or something light or wiggle the timer knob and see if it starts,also did you have this on timed dry?it sounds like the timer died and then somehow power went through it again and it ran,the timer controls how long the dryer will run so this is why i think it could be the timer,or a broken wire but try wiggling the knob and see if it starts.let me know thanks.
12/23/2017 11:33:48 PM • Whirlpool Inglis... • Answered on Dec 23, 2017
When replacing belt does the rib or flat side face the drum
find the drive pulley and if the ribs fit the pulley then that is how it is on the drum
11/24/2015 9:33:28 PM • Whirlpool Inglis... • Answered on Nov 24, 2015
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs, you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies. good luck rod
4/24/2015 7:48:43 PM • Whirlpool Inglis... • Answered on Apr 24, 2015
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
8/16/2014 3:35:38 PM • Whirlpool Inglis... • Answered on Aug 16, 2014
Whirlpool Dryer IED4400SQ0 wont get hot
Did you pull the element out and test it? I think it is your heating element. Visually inspecting is never enough. Just hook it up to high voltage independently to ensure it heats. It will turn red hot.
3/13/2014 11:24:53 AM • Whirlpool Inglis... • Answered on Mar 13, 2014
Whirlpool Dryer IED4400SQ0 wont heat
Check your thermal fuse and the thermal cut-out fuse, two different fuses that can cause a dryer to run and not heat when open, or some dryers will not start when one of these has gotten too hot and opened....Usually caused by venting restriction of too much lint, common problem........... A open operating thermostat or the high limit being open are also possible........;. The other checks are live voltage checks, timer contacts, wiring, temp and internal motor switch......schematic is probably in back of control panel........ Takes some reading of a wiring diagram, understanding how to split the circuit ............Not for beginners.............Hope this helps...........do not forget to unplug dryer when doing anything on unit besides live voltage checks on circuits,,,,,,,,,,,,,,,
3/13/2014 11:21:44 AM • Whirlpool Inglis... • Answered on Mar 13, 2014
I changed the dryer cord from 4 wire to 3 wire..
There are 4 wires for a reason. The heaters require 220 volts and the white wire helps give 120 volts to the motor and control circuits. Altering these without any knowledge of electricity results in the control circuit and or the motor blowing up. Here in Canada and USA anyways
10/15/2013 2:23:19 PM • Whirlpool Inglis... • Answered on Oct 15, 2013
Wire leading to coil keeps burning out
Check the coil for proper resistance. IT could be too low. Replace the coil the next time you replace the wire. The coil could be expanding and touching ground and causing excess current issue.
8/10/2013 3:01:19 AM • Whirlpool Inglis... • Answered on Aug 10, 2013
My dryer will not start. replaced thermal fuse ran for 1 load, heated extremely well. now will not start again
Did you check the fuse?Check the venting pipe, I think you have some problem with the venting
3/14/2013 12:59:10 AM • Whirlpool Inglis... • Answered on Mar 14, 2013
Dwjr-ele-2406026-fm54
Hay Kirk , most likely your door switch needs to be replaced if that doesn't help test all three fuses for continuity . good luck APPLIANCES R EN
3/3/2013 2:09:38 AM • Whirlpool Inglis... • Answered on Mar 03, 2013
Dryer not drying
It could be the heating element but do not assume it is until you check it. If the element is fine the limits on the heater housing might be tripped and if that is the case the vent needs to be checked for blockage. Birdnest, snow, cobwebs, and such can cause limits to trip. On an electric model the fuse mounted on the blower kills the motor but on a gas model the fuse kills power to the gas valve. I have a full page of dryer repair info and service manual HERE If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/14/2013 2:42:29 PM • Whirlpool Inglis... • Answered on Jan 14, 2013
Whirlpool Inglis IP8200 Dryer Logo
145 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
whirlpool dryer ied4400sq0 wont heat
  • Dryers
