20 Most Recent Miele Novotronic T230C Electric Dryer Questions & Answers
Miele Novotronic T270c condensing dryer. The time display unit not working.
Question edited for clarity. Add maker and '(what is is)'. Question moved from Washing Machines to Miele Novatronic. Call for service 'Immer Besser'. Or get behind the display and check all the connections. It may need a new Control Board and that needs professional diagnosis. https://www.google.com/search?q=Novotronic+T270C+time+display+unit+not+working ..
1/30/2024 9:25:07 PM • Miele Novotronic... • Answered on Jan 30, 2024
0answers
Be the first to answer 2/12/2018 7:00:04 AM • Miele Novotronic... • Posted on Feb 12, 2018Be the first to answer
2answers
Drier stops drying while clothes are still wet.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
3/19/2015 11:45:26 PM • Miele Novotronic... • Answered on Mar 19, 2015
How can I reduce the humidity of the air expelled from the dryer?
If the aire being expelled is humid then this suggests that the unit if working fine. if clothes are still damp then maybe give them a second spin before putting in the drier, or dry them for longer. Also try putting less in the drier and drying in two loads.
10/25/2014 10:10:43 AM • Miele Novotronic... • Answered on Oct 25, 2014
0answers
Not heating
If you can hear the dryer start and operate but at end of cycle your clothes are wet then it is likely (assuming the heater is turning on) that the fluff collection on the condensor unit is blocking its operation. Refer manual at this site and follow instructions on page 20. http://www.eirvik.is/gogn/L/t233c.pdf
4/19/2014 10:03:27 PM • Miele Novotronic... • Answered on Apr 19, 2014
The dooron my T430 keeps poping open for no reason- even when empty?
Thank you so much. My family is happy the heater is working again- Kind regards from Germany
11/21/2013 8:07:14 PM • Miele Novotronic... • Answered on Nov 21, 2013
2answers
The empty container/pc light comes
at the back of the dryer there should be a plastic tube from top to bottom ( this is the overflow pipe from the water container that needs to be emptied after each use, if the container is allowed to fill up, the water gts picked up by this pipe and collects at the base of the machine, stupid idea, i know) undo the clip at the bottom and empty the tube, also, with the tube still of, tilt the dryer and if loads of water comes out where u disconnected the tube you just need to get the water out. re connect the tube and bobs your uncle. hope this helps. p.s u may want to remove the top cover ( 2 screws ) and blow down the tube to make sure it aint blocked. when re fitting the tube, dont be scared of bending it to get it back into the slot where it tucks into the machine
11/21/2013 8:06:27 PM • Miele Novotronic... • Answered on Nov 21, 2013
"Empty the container" light is on and machine
Check for a kink in the drain hose.
11/4/2013 6:47:19 AM • Miele Novotronic... • Answered on Nov 04, 2013
Miele Novotronic T230C Electric Dryer Logo
70 questions posted
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
View Most Popular
Miele Dryers
  • Miele Dryers
Most Popular Question
miele t230c service manual
  • Dryers
