At first the trays had water but wouldn't turn into ice and my ice cream melted also so I removed the back panel on the inside of the freezer side and defrosted the coils. The ice maker resumed making ice but only a couple of times. Now the tray have no water. Checked the hose behind the refrigerator for blockage. Water runs through. Inside temperature for freezer is below 30F.
Thank you. Yea I thought about that. A friend told me it needed freon. ??? I thought the new technology did away with freon but I'm no expert. I'm looking at the thermostat. I don't know if it is working or not.Thank you. Yea I thought about that. A friend told me it needed freon. ??? I thought the new technology did away with freon but I'm no expert. I'm looking at the thermostat. I don't know if it is working or not.
You can't post conmments that contain an email address.
* Ice cream makers are small tub partial filled with cream, sugar, and flavor.
* This cream tub is placed inside a larger bucket containing ice and salt (usually rock salt). The salt makes the melted water almost as cold as the ice. (colder than regular unsalted water)
* Creme in contact with the metal tub gets frozen and creates a layer of frozen creme around the tub.
* The frozen creme is soft due to the fat in the creme preventing the liquid from freezing hard.
* Scraping away the semi frozen cream allows more liquid cream to freeze on the cleaned sides of the inner tub.
* with continuous scraping the cream will form a semi frozen "Milkshake" like thick liquid. It will not harden as the large ice bucket would have melted all the ice by then.
* Remove the semi-frozen cream. Serve immediately or pack in container to continue freezing cream. It should harden when left over nite in freezer.
* Using bucket; https://www.youtube.com/watch?v=o_IFfVdOE2g
* Using bowl; https://www.youtube.com/watch?v=t7aUHywPnog
* Using Ziplock; https://www.youtube.com/watch?v=y-69y9GsS_4
* Enjoy!
Aloha, ukeboy57
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in here generically, if you read and study the solutions very,very carefully. Check Temp inside freezer. It has to be down to about 10 or 15 degrees This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees See if water is in icemaker. Pour water in Ice Maker and wait to see if it ejects. If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that attaches to water line out of wall) If it doesn't eject then it is a faulty Ice Maker. If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing First I would check the fan in the freezer. Listen to see if it is running It moves air to the ref from the freezer Then check to see if freezer control is turned WARMER, which makes the Ref. colder Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace the water valve at the bottom rear of the fridge. It is a double valve and one side is not working Also this might be a common Defrost problem, Ice is not being melted by the defrost system.The fan can't blow through the coils into the fridge. Take out back panel of freezer to check for ice buildup. The coils should be clean. There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card. Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check fan undernearh Ref in the rear Clean condenser coils underneath .I'm including my article on Refrigerator Repair for your help and convenience.; Please click or copy and paste into browser for Article http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically Thanks for using fixya Leo Ponder imufo2 PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
Ice maker stopped making
ice or filling with water . For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the
water is not filling in the ice maker chamber then it's clear that ice is not
getting made due to no water in the chamber. For no water filling, the problem
is either water supply valve turned off so water is not filling. Turn on the
water supply and it will fill. But if the water supply is turned on then the
other possibility is ice blockage in the water fill tube. There is a tube from
which the water runs and enters the ice maker chamber. If this tube is blocked
then water will not enter the chamber. The tube needs to be defrosted, by using
hair dryer. This procedure melts the ice collected in
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve at the back of ice maker is faulty. Replace the valve.
You can get required
parts from sears part direct online site or from repairclinic.com site.
ice. For this problem you have check few things. First thing, is the water
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The waterinlet valve on the back of the unit where the
water supply comes in can have a slow leak and will cause ice to buildup and block
the fill tube. Disconnect the ice maker line from the valve and watch to see if
it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water
preventing it from closing or low water pressure.
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
