20 Most Recent U-Line Icemaker Questions & Answers
Tell him to first fill ref-regent gas in compressor cause if does not have enough the comp will over heat a cut of .
U-Line Icemaker | Answered on Jun 06, 2018
It does sound as if you may need a new ice maker. Other than that does the compressor come on to keep the ice cold? If so is it making any type of noises beyond the typical hum?
U-Line Icemaker | Answered on Jun 10, 2017
Sorry we do not sell this product or any other. Please contact the manufacturer.
U-Line Icemaker | Answered on Apr 21, 2017
Follow this link. This should help with your uline not making Ice.
line ice maker model ULN B12115 not making ice
U-Line Icemaker | Answered on Aug 01, 2016
This is usually caused by a bad water inlet valve. This part is usually found behind the fridge at the bottom behind a panel on the fridge itself. It has 1-2 water lines running into it and 1-2 wire harnesses connected. You need to turn off the water going into the fridge and cut the power to the fridge to access this part. You can buy a new one at a local appliance parts store or online.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_b814bade9ade93ea
U-Line Icemaker | Answered on Apr 19, 2016
If water keeps running after the fill cycle is usually indicates a bad fridge inlet valve. This valve controls the amount of water going into your icemaker. It is found where the water line goes into the fridge, usually in the back of the fridge at the bottom. You would need to cut the power to the fridge, turn off the water supply going into the fridge and remove a panel to get to it. You can check out online what a fridge water inlet valve looks like so you can identify it. It usually has 1-2 water lines going into it and 1-2 wire harnesses attached. You can buy new ones at a appliance parts store or online.
leaking water tray or water level to high check for any cracks and check water level after first harvest
U-Line Icemaker | Answered on Feb 03, 2016
time to get the compressor replaced .
U-Line Icemaker | Answered on Aug 05, 2015
U-Line Icemaker Logo
488 questions posted
Top U-Line Kitchen Appliances - Others Experts
John Powell
Level 1 Expert
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Kitchen Appliances - Others
Most Popular Question
after power outage ice maker stopped
  • Kitchen Appliances - Others
